light beams high/low....
Old Sep 3, 2003
SatansEnemy's Avatar
SatansEnemy is an unknown quantity at this point
Lightbulb light beams high/low....
ok i noticed the other night, you can turn the high and low beams on at the same time....
you know the light control.....if you pull it to you, you can flash your high beams....well if you hold it in the right position, it will have both the high and low beams on at the same time.....
I was wondering if anyone knew how to make it that when you had the high beams on, that it would turn both on.....
i hope someone can understand what im trying to get across......
well get back to me.....if anyone knows how to accomplish this.
thanks,
WorM
Old Sep 3, 2003
streetglower's Avatar
I know what you are talking about, I had done it several times when I had my stock lights on. All I can really say is that you would have to rig your headlight wiring up somehow. hope that helps somewhat.
Old Sep 3, 2003
i kinda figured that...but i dont want to start cutting into my wires, without have a diagram or sumthing, you know?
i appreciate any help i can get....
Old Sep 3, 2003
I feel you, I was going to recommend not messing around with the wires unless you know exactly what wires you are going to work on cause messing up the wiring for the headlights is an expensive part usually found only at the dealership.
Old Sep 3, 2003
that is a good question though that you asked, that should be a DIY if someone knew how to do it.
Old Sep 4, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
get a wire tester... what happens is.. that in the 3 prong connector... 2 wires are ground.. and one postive... when u put the high beams on they switch... how do u expect to have both lights on when they're the same bulb... i dont understand what ur sayin.. its impossible to have the high and low on at the same time.. we have ONE BULB.. DUAL filament.
Old Sep 4, 2003
it is possible if you have the switch in the right place, I have done it too. It is tricky though.
Old Sep 4, 2003
Jackseric's Avatar
Jackseric is an unknown quantity at this point
It is possible and not tricky either.
You have to have high beams on already. Then pull and hold the lever back after the click and you'll be burning both filaments at the same time. Don't know why, but it doesn't work when going from low to high.
Also... bad idea to wire it up to do it permanently. Both fils burning at same time significantly increased the temperature in that bulb... you'll be VERY likely to melt expensive sheeot!
Old Sep 4, 2003
i was wondering if it would melt sumthing......i figuerd it might would.....but was hoping it would work safely....cause its bright as ****, with both on, and looks cool as hell.
well im out....thanks for all the responses
Old Sep 4, 2003
it would also probably decrease the life of the bulb with all of that wattage going through.
Old Sep 5, 2003
DPRcivicSedan's Avatar
DPRcivicSedan is an unknown quantity at this point
i did this for my truck, they sell a kit for it, its a relay that you have to tap with a wire splicer between the low beam and high beam. when the high beam goes on the low beam goes on too. $50.00
look for it. i'm not sure if it would work with our cars.
but then again its two different bulbs for low and high on my truck....if you had some aftermarket projectors maybe......you probably could do it.
they call it a high 4 headlight kit for trucks. it basically makes your high beams driving lights.
hope that helps...
themechanic
Lighting
Feb 2, 2018 09:23 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
stryder12
Jun 30, 2015 08:33 PM
ericaagarcia
Jun 11, 2015 11:29 AM
klam
Nov 19, 2001 05:46 AM
