stock spring install question?
Old Aug 18, 2003
specks's Avatar
specks is an unknown quantity at this point
Hello fellow 7thgen owners, I was wondering if someone can answer a question for me.
The situation is that I'm trying to put my car back to stock and my first step is raising my car back up with its stock springs but the problem is that in the rear, I have already cut the foam bump stops....Do I need a new bump stop or will that not even matter because i'm assuming it doesn't but not so sure. any insight would help greatly...thanks
I forgot something also, if anyone wants the adjustable ground controls, its for sale.
I'll post it in the marketplace forum.
Old Aug 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
there is a suspension forum, try searching there!
Old Aug 18, 2003
flotsamm's Avatar
It shouldnt matter to much, unless you think you'll be carrying heavy loads. Since your raising it back up, your lessening the chance of bottoming out. Best thing to do is buy a set if your skeptical.
Old Aug 18, 2003
civicvtec1ps's Avatar
Search and Learn
http://www.7thgencivic.com/forums/fo...?s=&forumid=44
you should be fine with cutted bump stop. you could always get new ones at dealer.
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
vtec_concept
May 24, 2015 10:27 AM
oneheadlight
Apr 29, 2015 11:30 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
wsking77
Aug 29, 2001 05:34 PM
