Question about radiator hose
7thgen Man-gina
Rep Power: 0 Question about radiator hose
ive got a hose sleeving kit which includes some sleeving to do the radiator hose. everytime i disconnect the radiator hose fluid spews all over me and fvcks up my air force ones i unscrewed the cap on top of the radiator which i thought would releave the pressure, but there was still fluid leaking out, so anyone have any ideas? should i add some since i had a little leak? thanks in advance
Rep Power: 287 First, go to the parts store and buy the proper coolant, your gonna need some. Its very important that you use the right coolant, when in doubt talk to a Honda Tech. Or, if you dont want to use the proper coolant and go cheap, just use some distilled water. This is assuming you didnt waste too much when draining..
On the bottom of the radiator is a drain plug for the coolant. When the engine and radiator has cooled off, unscrew the the plug and release enough coolant to remove your upper hose. Do your sleeving then top off the radiator.
BTW.. I know some peeps who've drained their radiator into a clean container and re-used it. I dont recommend it unless your certain you know what your doing.
Rob02Civic
09-16-2018 09:16 PM
7thgensurvivor
38
08-29-2015 11:50 AM
Lunar
05-22-2015 07:43 AM
deus-ex
04-13-2015 12:29 PM
