Catalytic Converter
Old Aug 16, 2003
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Question Catalytic Converter
Hello,
Here's my situation... I have the SF kit and my cat went bad on me. What would the differences be if I just bored out the cat or got a new hi-flow cat/mid pipe?
Old Aug 16, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
What do you mean by "differences"?
Old Aug 16, 2003
RoBBUsaF's Avatar
that's what i mean... there would be no difference... no restriction of airflow... right?
Old Aug 16, 2003
cdmx's Avatar
well cause of the turbo, its not gonna be as loud as if you didn't have a turbo
Old Aug 16, 2003
RoBBUsaF's Avatar
lemme rephrase the question... will the airflow be about the same if i bored out my cat as opposed to buying a new hi-flow cat?
Old Aug 17, 2003
Jeff's Avatar
Jeff is an unknown quantity at this point
I would be asking your turbo kit maker.
Jeff
Old Aug 17, 2003
Elite's Avatar
Elite is an unknown quantity at this point
boring out the cat would make airflow very good for the turbo which means maybe you can run more psi but I wouldn't without internals first, if you dont have internals its better to get hi flow cat which would cause some restriction but not always.
Old Aug 17, 2003
RoBBUsaF's Avatar
well i just got back from boring it out and wow... big diff... the whole cat is a huge restriction to airflow...
Old Aug 17, 2003
Bellz's Avatar
Congratulations! You're now illegal!
Old Aug 17, 2003
RoBBUsaF's Avatar
and your point is???
Old Aug 17, 2003
Bellz's Avatar
A replacement high flow cat isn't that expensive. And think of all the drivers you wouldn't offend with stinky exhaust if you had a new cat.
Old Aug 17, 2003
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
Yah like adding the turbo made him even more legal? Uhm no, if you're not in cali or some other car-dummy state then ya shouldn't worry about emmisions
Old Aug 17, 2003
CapYoda's Avatar
Escaped Convict
I'm currently suspecting my cat is out too... or rather, clogged... causing excessive backpressure and the car can't speed up or lags or stalls sometimes.
this happens when theres low fuel in the car... and overall performance is greatly decreased too..
the exhaust gas shoudlnt' have been hot enough to do that... I think most cause of cat clogging is cause by the engine running too rich.... and excessive unburnt fuel reachs to the cat, and burns up there.. melting the catalyic....
I duno why its very evident when the car is low on fuel... for me it might be other problems, such as fuel filter clogged... was ur problem more evident during low fuel in the tank?
u should probably make sure u're not running too rich or lean...
what caused my problem was a leak in my exhaust manifold gasket, and I think it was constantly running rich for a long time... eventually killing the cat.
and if u can bore out the cat.. then do that. no point spending the moeny on a mid pipe if u can just clear the cat.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Luluharp
Sep 27, 2015 11:56 AM
pilebuck13
Sep 21, 2015 10:45 PM
Dsmak
Sep 10, 2015 08:30 PM
