Water Temp gauge
Old Aug 12, 2003
RSDCivic's Avatar
RSDCivic will become famous soon enough
Question Water Temp gauge
ok I just got my water temp gauge and I'm trying to hook it up... is there a way to just tap into the sensor thats already there or do I need to use the provided temp sendor....? and if I do need to use the temp sender where the f*** does it go?
Old Aug 12, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
You need to tap the sensor into the radiator hose going INTO the engine. Thats really the only way to do it. The stock one isn't sensitive enough.
Old Aug 13, 2003
RSDCivic's Avatar
aight cool thanks man!
Old Aug 13, 2003
clownprince's Avatar
Ricerus Maximus
Going into? I would figure temp coming out would give a more acurate reading of actual engine temp.
EDIT: never mind, wrong gauge, I was confused.
Old Aug 14, 2003
RSDCivic's Avatar
ok... if I put the sensor in the hose is there any chance of that hose leaking... say if I just drill a small hole in, shove the sensor in and seal it off? seems a little sketchy
Old Aug 14, 2003
Jap-Euro Fusion
You need a real fitting. Don't ghetto rig your cooling system. Do it right. Probably best to let a shop that knows what they're doing set it up.
Old Aug 16, 2003
RSDCivic's Avatar
good call... thanks again
mjdiaz89
Jun 21, 2016 09:26 PM
Doug Lassiter
Aug 9, 2015 09:31 PM
Ronin Nishimura
Jul 28, 2015 07:24 AM
silentz
Jul 9, 2015 08:16 PM
cgavin1
Jul 7, 2015 07:10 AM
