Intake
Old Jul 18, 2003
02civic's Avatar
Need....More....Mods
02civic is an unknown quantity at this point
Intake
I picked up a Redline Intake (generic) today and took a look at the AEM DIY and the parts i got in my kit arent exactly the same. Anyways my question is the brackets in the AEM kit...i dont have anything that look like them...i've got a small flat piece about 2" long with a 90 bend and another inch of metal....its gotta hole at the long end for a nut. I assume this is a mounting bracket since my piping does not have one already on. The second one is a long flat piece about 5or6 inches long and with 2 holes at one end and a single hole at the other. I'd love some help to figure out just how these pieces are supposed to be used. Also the (what i think is) small mounting piece with the 90 in it.....does it get spot welded on or what?
Old Jul 18, 2003
civicvtec1ps's Avatar
Search and Learn
you are proabably missing a part .
can you take any pics?
that would help...
Old Jul 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
Why don't you just follow the instructions that came with your intake, I hope it came with instructions, because anything like that should!
Old Jul 18, 2003
02civic's Avatar
that is the funny part.....no instructions
i have figured out that the smaller piece in the mounting point that i will need to spot weld on....or i could attach it down low (outta sight) with zip ties.....that should keep her from moving around too much. The second piece i figure is for the throttle cable......i think....i dunno....i would take pics but i dont have a digi cam.....
Old Jul 18, 2003
JaysAutoLX's Avatar
JaysAutoLX is an unknown quantity at this point
I'd take the b!tch back, and get the AEM intake. Pretty sure that will come with instructions.......
Old Jul 18, 2003
cdmx's Avatar
If you email the seller he will email you directions...what a dumbass that seller is
Old Jul 18, 2003
cdmx's Avatar
look there is NO difference with damn pipes....the only difference is if you get a LARGER DIAMETER PIPE....I belive the injen is largest...BUT ebay has the same generic intakes...all you have to look for is in the pic..If they show a coupling thats smaller on one end and bigger on the other that means its a large diameter pipe and not like my cheap *** intake thats only like 2.5"........check the pics! Also the filter comes into consideration also...i just bought a stainless steal filter and damn it looks so thin! get one of these filters
Old Jul 18, 2003
cdmx's Avatar
your paying for the brand is pretty much what that last post meant
Old Jul 18, 2003
redcivic02's Avatar
redcivic02 is an unknown quantity at this point
Is you ride a auto or Stick? is your intake a short or cold air?
If it is a stick with a cold air, your bent bracket might be for the relocation for the clutch bracket! That is the way my AEM mounted up.
Old Jul 18, 2003
cdmx's Avatar
Mine did not mount just right so i used a zip tie...I think its much better
Old Jul 19, 2003
poor jaysun's Avatar
poor jaysun will become famous soon enoughpoor jaysun will become famous soon enough
Originally posted by cdmx
... i used a zip tie...I think its much better
Nice Magiver
and
Love the AVATAR, I'd hit it too
Old Jul 19, 2003
02civic's Avatar
its a stick and a CAI
i figure that the bent piece is four mounting to the motor somewhere...cause there isnt any welded on mounts....i'll probably zip tie it too though. *** spot welding that ****....crap isnt even the right colour as the intake!!! I think the long piece is the clutch bracket. The AEM is kinda like a flat 90(and a bit more) with 3 holes. Well mine is a straight peice of similar length wiht 3 holes also....we'll have to see how it holds...
LAST QUESTION
do you think a zip tie down low will be sufficient to keep it from shaking to much?
Old Jul 19, 2003
Originally posted by 02civic
LAST QUESTION
do you think a zip tie down low will be sufficient to keep it from shaking to much? [/B]
I also heard if you use a wet tampoon and wrap it around, then heat/dry it with a blow dryer it will harden like concrete.
That's what I heard.
Old Jul 19, 2003
cdmx's Avatar
Yes very much, the zip tie does not let my intake move whatsoever...It probably wont last as long as a bolt but works just as good
Old Jul 19, 2003
02civic's Avatar
alright then i'll give her a try, worst case scenario is it is too loose and i take it to a shop and have to spend 20$ getting it spot welded
thanks to all for speedy replies....i'm off to work on my baby
Old Sep 8, 2003
asianmatrix02's Avatar
asianmatrix02 is an unknown quantity at this point
how did you guys install the generic intake from ebay w/o the tranny bracket? this one from ebay has looks like it has the tranny bracket but it is missing the welded tabs on the intake.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2431646734
also is it better to get an intake w/o the tranny tabs but with the welded tabs or this intake.
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Nov 9, 2015 06:31 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
