2003 Honda civic went to replace a sensor but it is not there.
Hybrid Engine/IMA battery systemThe hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone.
If they are same as the regular cars, please post there instead.
2003 Honda civic hybrid can’t find bank one sensor 3 location.I have looked all over the tail pipes but can only find 2 o2 sensors.I currently have a check engine light for these 2 codes p0147 and p1130.I have already bought the sensor but can’t find the location of it.
Re: 2003 Honda civic went to replace a sensor but it is not there.
I have exactly zero experience with the hybrids, but a parts diagram is showing one sensor on the header (which I see in your picture) and then two more underneath on the second catalytic converter.
thanks for the reply where did you find the diagram.There should be 2 catalytic converter I only found one that is by the headers.I could only find 2 sensors and it is the ones by the headers.
Found the diagram on HondaPartsNow.com. Under engine, look at exhaust manifold. There's another section that mentions exhaust and shows the rest of the setup.
so I’m missing a cat after the 90 degree bend.i recently bought this car for cheap with a cel I didn’t think it would be missing the whole cat.
Your second/third picture are from the back of the car, correct?
Diagrams show one cat integrated into the exhaust manifold, then the second in the down pipe right after.
yes second and third picture are from back of the car I don’t see one after the Down pipe I’ll check again later today and send more pictures.Im curious what happened to it.
Originally Posted by Colin42
Might be able to use a spacer and trick the sensor
What would be the steps to install a cat will a shop have to do it.Also the car does jerk when accelerating from a dead stop.Could this be do to a missing cat i also have o2 senosr codes.
