Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
IMA battery passed voltage test? [solved]
Old May 3, 2023
capnbutter1's Avatar
capnbutter1 is an unknown quantity at this point
Took my 2004 Honda Civic hybrid battery out to test it because my battery light was on and so is my ima light. Took it apart and noticed this red wire was sniped. Does anyone have a clue what this wire is used for and if so is this my issue. It text fine and seems like it’s a working battery
Top Answer
May 4, 2023
sdaidoji
re: IMA battery passed voltage test? [solved]
here, from googling 2004 civic hybrid battery and selecting "images"
Old May 3, 2023
connect it. pretty obvious where it should be going
read around about how to avoid shocks from battery first, though
Old May 4, 2023
Colin42's Avatar
That looks like a vent tube
Old May 4, 2023
maybe not, it is connected on the other end
Old May 4, 2023
of course, it could just short and cause a fire
not an expert on hybrids by any means
Old May 4, 2023
Old May 4, 2023
BrotatoChip's Avatar
Super Moderator
Re: IMA battery passed voltage test? [solved]
I thought it may have been some hacked wiring someone added but the way it routes seems to be from the factory.
Old May 4, 2023
oh, you still having issues to see the pictures? The one i posted shows the same wiring, but connected
Old May 4, 2023
Super Moderator
For whatever reason I cannot see your pictures. However, I could tell you posted one and looked on my phone. The hacked wiring though was before I saw your picture.
Old May 4, 2023
Colin42's Avatar
It goes to that terminal. No idea what the function is.
Old Jul 26, 2023
HonkingAntelope's Avatar
HonkingAntelope is an unknown quantity at this point
I've read elsewhere that cutting this wire was one of the "fixes" Honda did when the first gen batteries started dropping like flies and the high failure rates were going to cause regulatory issues in states like CA.
wilberfan
Apr 21, 2016 04:16 PM
Boilermaker1
Engine Swaps
Jul 17, 2006 09:32 AM
jason_wu
Dec 20, 2003 08:55 PM
