Hybrid Engine/IMA battery system The hybrid have a very different engine and Battery system (IMA), so this forum is for items related to the Hybrid cars alone. If they are same as the regular cars, please post there instead.
HCH-I DC-DC Converter Pinout
Old Apr 16, 2016
Vishvamat's Avatar
Vishvamat is an unknown quantity at this point
I have been unable to access a 2003-2005 CIVIC HYBRID Electrical Troubleshooting Manual.
Can somebody please confirm whether this is the correct pinout for the DC-DC Converter connector?
1 - Ignition (switched +12V)
2 - Battery Warning Light
3 - DVC, from Engine Control Module
4 - Not Connected
5 - DVCT (pulse width modulated), from Engine Control Module
6 - Inhibit, from Motor Control Module
7 - TDV (thermal disable), from Motor Control Module
8 - Sensor Ground, from Motor Control Module
Old Apr 16, 2016
Re: HCH-I DC-DC Converter Pinout
4 - Not Connected
5 - DVCT
The labels on my wiring diagram seem to agree with these
Old Apr 17, 2016
Vishvamat's Avatar
ezone, THANK YOU VERY MUCH!
This means the DC-DC Converter on the Insight mk1 (TDK MSE224) and Civic Hybrid 1 (TDK MSE298C) should be electrically compatible. They are mechanically different, with the MSE298C being 5.5cm shorter.
Old Apr 17, 2016
mac25's Avatar
Dr Krieger of Modification
Old Apr 17, 2016
Programming may be different......IDK, no real info about it.
I don't remember seeing problems with the converter, but at this point just about every one of those cars I see needs an IMA battery.
BrianDye
Oct 31, 2015 10:59 AM
EuroCivic
Dec 7, 2001 12:56 PM
Sledge
Dec 7, 2001 12:09 PM
my2k1vic
Nov 29, 2001 10:29 PM
TOOLOWCIVIC
Nov 18, 2001 10:17 AM
