Honda Civic Si Forum Honda Civic Si Forums - Come here to talk all about the venerable Honda Civic Si, both new and old. Threads or posts about the 2006 Honda Civic Si should be put in that forum.
2007 Honda Civic Si sedan
Old Nov 1, 2006
blue00si's Avatar
blue00si is an unknown quantity at this point
Talking 2007 Honda Civic Si sedan
The all-new, 4-door 2007 Civic Si Sedan has it all—all the performance of the Si Coupe combined with all the room and convenience of a sedan. This 6-speed, 197-horsepower sedan boasts a 16-valve, DOHC i-VTEC® engine with an 8,000 rpm redline for a powerful ride. Attack curves with a helical limited-slip differential, 17-inch alloy wheels and available high-performance tires. Turn up the 350-watt audio system with 7 speakers including an 8-inch subwoofer and an MP3/auxiliary input jack. Let the available navigation system guide the way, take hold of the aluminum and leather shift ****, sit back in the deep-bolstered sport seats and enjoy the ride.
from autosite.com:
Honda Civic Si Sedan – First Drive: One year after debuting a redesigned Civic Si and ditching the unpopular hatchback body for a traditional two-door design, Honda unleashes a sedan variant of its hot little econo-sport coupe because it has determined that young compact car buyers prefer the utility of sedans and hatchbacks over coupes. Huh. Normally it’s Ford that chases its own tail around like this. Whatever. The point is that if you’ve been craving a terrifically fun small car as a replacement for the V6- or V8-powered gas hog that currently sits in your driveway, the 2007 Honda Civic Si Sedan is here to meet your need for speed and practicality.
With this quick little four-door, Honda is aiming at the same group of young, educated men that buy the Mazda 3, Nissan Sentra SE-R, Mitsubishi Lancer Evolution, and Subaru WRX because “fun-to-drive” is high on their list of purchase considerations. Honda’s research says that “fun-to-drive” is not a priority with Civic EX buyers. Honda’s research also says that the top trade-in model for these four “fun-to-drive” competitors is a Civic. Slapping that high-revving four-banger into the Civic Sedan and decorating it with all the same goodies that come on the Si Coupe was a no-brainer, and the result is the 2007 Honda Civic Si Sedan, which comes standard with “fun-to-drive.”
Honda invited us to the Motor City to drive the new Civic Si Sedan. Yeah, not the first place you think of when the phrase “great driving roads” comes to mind. But one of the Civic Si’s best traits is its tight, nimble feel when dicing through traffic, so the Dearborn area’s grid layout helped to showcase this part of the car’s personality. We resisted the urge to run over to Ford’s Glass House headquarters and drive rings around the building just as fast as we could, sticking instead to the auto-cross course Honda mapped out in the parking lot of the Hyatt hotel and to the city streets, freeways, and parkways nearby, and came away favorably impressed with this hot little family hauler.
Honda plans to launch the 2007 Honda Civic Si on November 1, to coincide with the annual Specialty Equipment Marketing Association (SEMA) trade show in Las Vegas. The price is not officially set, but Honda thinks it will mirror the Si Coupe, with a starting price of about $20,000. Add the voice-activated navigation system with XM satellite radio and the stickier summer tires, and the price will jump to about $22,000. Honda plans to sell about 15,000 units annually.
It should come as no surprise to anyone that the 2007 Honda Civic Si Sedan is essentially the same as the Si Coupe, but with two extra doors, 59 extra pounds and a few unique tweaks. Honda’s 2.0-liter iVTEC four-cylinder engine belts out 197 horsepower just 200 revs shy of redline at a lofty 7,800 rpm, and cranks 139 lb.-ft. of torque at 6,100 rpm. If you’re in Honda’s target market for this car, you’re doing the math right now. These figures do, indeed, indicate that you’re going to spend lots of time thrashing on the engine to generate maximum power, and extracting every last ounce of motive force is gonna require some serious attention to detail – especially when the standard five-year/60,000-mile powertrain warranty expires. And if you’ve got a soft spot in your heart for polar ice caps, you oughta know that this engine is the only one in the Civic lineup that isn’t rated LEV II ULEV or better.
As in the coupe, those ponies flow to the front wheels through a six-speed manual transmission and a helical limited-slip differential. An automatic transmission is not a part of the Honda Civic Si equation, so if you can’t shift for yourself, maybe you should buy a car that just pretends to be a sport sedan – like a Chevy Cobalt SS four-door. Alternatively, choose the Civic EX, which is plenty more fun to drive than most people think while getting 40 mpg on the highway.
The Civic Si Sedan’s MacPherson strut front and double-wishbone rear suspension is tuned a little differently and gets a 1mm thinner front stabilizer bar to offset the weight gain over the coupe, and while Honda says the Si Sedan is a tick slower to accelerate than the Si Coupe, it promises that handling and braking capabilities are identical. Bright silver 17-inch alloy wheels are shod with P215/45R17 all-season tires and guided by electric rack-and-pinion steering, but for $200 buyers can select summer rubber in the same size. Ventilated front and solid rear disc brakes bring the Civic Si Sedan to a rapid halt, enhanced with ABS, EBD, and a stability control system. Honda has also tuned the Si Sedan’s exhaust differently for a more powerful note in the low-rpm range.
Old Nov 1, 2006
blue00si's Avatar
Old Nov 1, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
single piston calipers??!!!! well that's safe.. imo anything over 120 hp needs at least dual piston.. at least once you pass up 150 hp..
Old Nov 2, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
Yea Makes You Wonder Dont It.
Old Nov 2, 2006
blue00si's Avatar
it only weighs 59lbs more than a coupe
Old Nov 7, 2006
kero's Avatar
kero is an unknown quantity at this point
looks nice but if it has problems like most other new civics have, what's to be excited about?
I liked my 1986 civic SI 1500 better than my 06 LX
Old Nov 7, 2006
blue00si's Avatar
ok you cant compare a Lx to a Si...everyone that i know thats driven or bought a 06+ si absolutely love it....i still wanna drive an own one
Old Nov 10, 2006
06CivicHybrid's Avatar
06CivicHybrid is an unknown quantity at this point
what problems do you speak about?
Old Dec 12, 2006
qcivic's Avatar
qcivic is an unknown quantity at this point
i just piced up an 07 sedan in alabaster silver/ navi. after the rain stops i'll post a pic. i tinted the windows and added a 12in jl audio comp sub and amp. the sound system is amazing. we left the stock sound sys in tact.
Old Dec 16, 2006
qcivic's Avatar
here is a pic of my new car.
Old Dec 17, 2006
blue00si's Avatar
im so jealous....i want a 4dr si hows the exhaust sound? they tweeked the sedans exhaust to be deeper at lower rpms than the coupe
Old Dec 17, 2006
qcivic's Avatar
it does have a deeper sound imo. btw i work in the sales dept @ the dealership i got 1st dibbs on the Si when it arrived. i bought the very 1st 06 civic lx sedan that landed on our lot in the fall of 05. i told myself after driving the 06 Si coupe that if honda ever made a 4 door Si that i'd get one. i wanted navi and this was the 1st on our lot. tomorrow i should have 600 miles on the car so i can jump on it
vtec92
May 4, 2017 03:20 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
jessicakaybby
Apr 20, 2015 12:11 PM
dano2005
Apr 14, 2015 01:58 AM
