Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Help with vtec !!!!!!!!!
Old Aug 23, 2010
brobo's Avatar
brobo will become famous soon enoughbrobo will become famous soon enough
Exclamation Help with vtec !!!!!!!!!
I am new to this stuff but work on cars i sorta know how electronics work but i know the internals like pistons etc. but i was wondering is there and requirements for vtec to kick in like
no check engine , oil etc
SPECS: 2001 CIVIC EX AUTOMATIC
D17A2 WITH CATBACK EXHAUST
ITS A VTEC WITH 40K ON ENGINE
140K ON BODY AND TRANNY
SO THANSK for the replys
Old Aug 23, 2010
Re: Help with vtec !!!!!!!!!
are you having troubles with the engine or is that just for curiosity?
Answers could vary
Old Aug 23, 2010
brobo's Avatar
curiosity cause i see all those k20's and shti got bam when vtec pops in and i know sohc is quiet but i wanna know if it works
Old Aug 23, 2010
if oil is low, they don't work. it's oil pressure that does the change.
Old Aug 23, 2010
lazlong's Avatar
Bingo. Oil pressure switch.
Old Aug 23, 2010
brobo's Avatar
so thats the only thing and how can i tell if it kicks in cause i know it switches at 3200
Old Aug 23, 2010
lazlong's Avatar
Pull the connector and check continuity between MALE connector terminals to see if it's bad. That's all I help with. sorry.
Old Aug 23, 2010
brobo's Avatar
i dont understand
Old Aug 23, 2010
lazlong's Avatar
i dont understand
Sorry, didn't see the post about being curious. You should feel/hear it kick in around 3000rpm. It's not a big increase, only 10 hp or so, so listen carefully.
Old Aug 23, 2010
http://www.hondacivicforum.com/forum...ad.php?t=26576
https://www.civicforums.com/forums/1...ight-pics.html
you can also do that
Old Aug 23, 2010
brobo's Avatar
k but what about 2001 civic its differnt
Old Aug 23, 2010
lazlong's Avatar
Dude, that was a civic. Go check, you have a Green/Yellow too.
Old Aug 23, 2010
brobo's Avatar
k thanks
Old Aug 23, 2010
brobo's Avatar
were is my vtec soleniod located in 2001 civic
Old Aug 23, 2010
get a civic repair manual in any car parts store (haynes) and you should have a electrical diagram of all your car. using that, you can make your own V-tec light.
That will also allow you to make several different repairs in your car yourself.
Note that i posted 2 different links, so check both.
Old Aug 23, 2010
lazlong's Avatar
v-tec solenoid:
v-tec oil pressure switch:
Old Aug 23, 2010
i think youre pointing at the EGR valve in the first pic. vtec solenoid is behind the engine head where the oil pressure switch screws into.
as for vtec engaging, a few conditions need to be met on the d17a2:
1. coolant temp must be at normal operating range
2. engine must be above 4800 rpms
3. oil level (and pressure) must be at normal levels
4. gas pedal must be floored (full throttle)
5. speed must be over 15mph
only when all these conditions are met will the ecu send a 12v signal to the solenoid and change the cam profile. yes, vtec is for racing use. if you manually adjust the vtec change-over rpm, you will gradually destroy the engine.
Old Aug 23, 2010
interesting, was not aware of the 1, 2, 4, 5
thanks
big guys are in the room now, so i will leave!
Old Aug 23, 2010
lazlong's Avatar
Fixed. Sorry, blond moment. lol
Old Aug 23, 2010
brobo's Avatar
i thought it was 3200 rpm
Old Aug 23, 2010
brobo's Avatar
wait you mean vtec light kills my engine
Old Aug 23, 2010
sorry, couldn't help when i read that portion!
Old Aug 23, 2010
non, non, changing the engaging timing will cause trouble in the long run
Old Aug 23, 2010
lazlong's Avatar
Ok, from the other thread about steel/aluminum oilpans on the A1 and A2 I figured out that I have an A2 in my 2001 EX. The v-tec comes on at about 2800rpm or so. This leads me to believe the previous owner blew the engine and put the original v-tec solenoid on it (among other things). Do you think I'm slowly destroying my engine, I've already run 70K?
Old Aug 23, 2010
sorry, have not an answer for that...
Old Aug 23, 2010
Connie's Avatar
If you do this make sure you can hide it away cause it get very very annoying. Definitely kicks on before 4K rpm according to the light in that DIY.
Old Aug 23, 2010
I did not do it!
they wanted to know how to make sure it was working, so this was one of the ways to be sure!
Is it useful? Not at all, actually.
Old Aug 23, 2010
I was actually thinking more about. (rare stuff).
Honestly, when the Vtec is not engaging, the ECU (smarter than most of the average drivers) will not let the engine rev above the engaing point of the VTEC, so just get over it. If the engine gets over 4k, say 5k, just forget it. VTEC is working and look for some other things, like old air filters holding the engine back.
end.
Old Aug 23, 2010
guys the vtec light does not mean that the cam is switching over. our engines use a vtec-e (economy) which is more complicated. im sure some stuff happens between 2800-3000rpms, but in order for full vtec to engage (all valves open, new cam profile), those conditions need to be met that i posted. why would vtec, a system designed for hi rpm driving with a more aggressive cam, come on when driving at low rpm? it would kill the gas mileage and make the engine run like crap. i wish i could find that thread when a member did all the testing with a data logger.
Old Aug 23, 2010
i found it!! heres what the member found out on a d17a2 when he was watching the readout...i remembered most of it lol. if you guys want to test this, you can hook a multimeter/voltmeter to the vtec solenoid wire while driving. unless it reads 12v, the vtec is OFF so to speak. if it reads only 3-9v (plenty of power to light up an LED), the vtec solenoid has not been activated.
1 Your MAP (Manifold Absolute Pressure) sensor must read 0hg (aka 0 inches of vacuum). When it reads this it will send a 3volt signal to the ECU.
2. Your throttle has to be open 100% because your TPS sensor has to send a 4.5-volt signal to the ECU.
3. Your coolant temp has to be at running temp.
4. Vehicle speed has to be above 20mph.
5. You have to have 65-80 oil psi.
6. The engine must be running at a minimum of 4500 RPM
When all of this happens your ECU sends a 12-volt signal to your VTEC solenoid.
