Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Need help about Car Led Lights
Old Aug 4, 2010
ehssan's Avatar
ehssan is an unknown quantity at this point
hi
i have Honda civic 04 and i am trying to install under car led lights through dome light. I did install 4 small blue tube light under dash inside the car and its also connected through dome light so when installing under car led lights through dome light should i put fuse on it or should i wire it without fuse. please let me know if any one have idea thanks
Old Aug 4, 2010
Re: Need help about Car Led Lights
Why don't you just use a relay and use the battery as a direct power source, use say, the parking lights or headlights as the relay's switch signal so they're only on when the parking lights or headlights are on..
You can even add another toggle switch so you can turn them on/off as you please, assuming the headlights of parking lights (as applicable) are on
Old Aug 5, 2010
micheecivic's Avatar
micheecivic is an unknown quantity at this point
You need to find out how many amps the lights combined pull and put a fuse slightly larger that that on it. Also this will need to be done through a relay, just add a relay in the engine bay somewhere, put the fuse on the battery side of the power pass through for the relay, you can have the ground come into the car and put a toggle switch on it so you can turn them on or off, and have the power for the relays switch circuit connected to the running lights. This way switch supplies ground for the trigger in relay, power for trigger is supplied by the running lights and the passthrough is fused power. I would not run anything bigger than this off the dome light fuse.
CarStuff
Dec 6, 2020 12:52 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
2k1TypeR
Sep 25, 2001 09:25 AM
