Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
A lot of problems! Need HELP!
Old Jul 24, 2010
batman8168's Avatar
batman8168 is an unknown quantity at this point
Thumbs down A lot of problems! Need HELP!
Hello everyone
This is my first time posting to these forums. I have a few problems with my car and I have no idea what to do. I am getting really worried about all these things because I really can’t afford to take it to a mechanic. I have a 98 honda civic ex 4 door.
The first problem is that whenever I am driving and I push the accelerator down, it goes, but around 30-40 mph, the rmp starts to drop a bit. So I push it down a bit more, and it takes a few seconds before the rmp jumps up again. This happens quite a bit, especially on the highway. I also noticed that the car doesn’t have the same amount of power anymore
Second, when this started happening, I noticed that whenever I open up my gas cap, a lot of pressure seems to be released. I know it is normal, but I don’t think that this much is normal.
Third, whenever I turn my car off, I hear an air leak from around the firewall on the driver side. I think that it is from the brake booster. How can I find out where the air leak is? My brakes have been bad for so long now. I just replaced the pads and rotors last year, and now they are shaking so bad whenever I brake.
Fourth, my speedometer doesn’t work anymore. This just happened today
My check engine light is on, and I have three codes. I lost two of them, but one of them is p0136: circuit condition (heated oxygen sensor bank 1 sensor 2). Probable causes: oxygen sensor defective, fuel system very rich or lean (check other codes first), engine misfire condition repaire, fuel pressure very high or low-fuel pump or pressure regulator.
The other two codes were about the same as these.
I really don’t know what to do or where to start. I am a broke medical student. I replaced my fuel pump, and o2 sensors. Please help!
Old Jul 24, 2010
Re: A lot of problems! Need HELP!
-for power loss, try changing spark plugs ($2 ngk v-power will do just fine) and plug wires (ngk) and also the distributor cap and rotor.
-air leak you can spray the vacuum lines with a soap/water solution and see where bubbles form when the car is running.
-rotors warp easily, try not to brake over 40mph or ride the brakes more than 5 secs next time
-speedo could be the cluster went bad, or the speed sensor, or the wiring.
-you need a new primary oxygen sensor, be sure it is the oem plug in type and not a universal unit. you may also need a new fuel pressure regulator. have the pressure checked before spending money on parts tho.
Old Jul 24, 2010
lazlong's Avatar
You can also carefully spray carb cleaner and listen for the idle to surge.
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
mrohitredd
May 28, 2015 10:03 AM
ywgflyer
May 15, 2015 05:05 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
