Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Is it bad to skip gears (go from 3rd to 5th)?
Old Jan 14, 2010
Obamargarine's Avatar
Obamargarine is an unknown quantity at this point
Sometimes when I accelerate off the light I go up to 3.5k rpm at 40mph in 3rd gear, so if I shift into 4th it'll be 2800-3000 rpm so I'll shift to 5th anyway.
So can I skip 4th gear alltogether and just go to 5th or is that bad for the car?
Old Jan 14, 2010
CraigW's Avatar
Re: Is it bad to skip gears (go from 3rd to 5th)?
When I used to "row my own" many years ago... I did the 3rd to 5th quite often, when possible I also did 1st to 3rd to 5th also.
Old Jan 14, 2010
CivicAK's Avatar
CivicAK is an unknown quantity at this point
ive heard its not good, if Im going downhill I skip gears but I notice even at high RPM when skipping a gear you just go back down to 1500.
So I say only do it going downhill.
Old Jan 14, 2010
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
I do it, name an actual reason its bad. If you release the clutch at the correct rpms I cant see why it would be bad.
Old Jan 14, 2010
That's what I'm saying, everyone says it's bad but no one actually says a reason. how does it damage the car?
Old Jan 14, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
It doesn't damage it at all as long as the RPMs are in a normal operating zone... If the RPMs are gonna go sky high or drop down to nothing then it's not good, but if it's nomal t hen I can't see why it would be an issue...
technically it's probably better for the clutch because you get to avoid the unnecessary gear change, right?
Old Jan 15, 2010
lordhelmet's Avatar
Could it be bad on syncros? To properly engage into 5th you need to be coming from 4th.
Old Feb 7, 2010
prsloco's Avatar
prsloco is an unknown quantity at this point
i heard shiftin like that saves gas......that was a surprise...........
Old Feb 9, 2010
9524tee's Avatar
9524tee is an unknown quantity at this point
I do it every single day... I would love to hear a good reason not to...
begogadashi
Jun 11, 2015 04:04 AM
tylerginevan
Apr 27, 2015 12:29 PM
EC3
Apr 22, 2015 07:55 PM
Poysynfree
Auto Transmission failures
Dec 13, 2001 06:08 AM
Desi
Nov 14, 2001 01:58 PM
