Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Defrost/Heat/Ac Fan
Old Jan 14, 2010
MaxwellT's Avatar
MaxwellT is an unknown quantity at this point
Defrost/Heat/Ac Fan
When I turn my '04 civic on in the morning the blower comes on fine. After some time it just shuts off and I can't get it back on. A couple of times while driving it just came on again although not blowing with the force you would expect. If I shut the car off and try to turn the blower on again it does not work. If the car sits for an hour or so then most times it will come on again. Anyone know what it could be? What could I check myself without having to go to a repair shop?
Old Jan 14, 2010
Re: Defrost/Heat/Ac Fan
check the transistor for the blower motor, it may be failing. its somewhere behind the glove box where the blower is.
Old Jan 15, 2010
MaxwellT's Avatar
Can anyone give me instructions on how to check this out?
Old Jan 15, 2010
#7 is the transistor
Old Jan 16, 2010
MaxwellT's Avatar
Where can I buy a new transistor?
Old Jan 16, 2010
CraigW's Avatar
With power off I would remove and reconnect (reseat) the connector at the transistor unit. Or with ignition and fan switch on try gently moving the connector to see if the fan trys to work when doing so.
The transistor would most likely be a dealer item.
Old Jan 16, 2010
RonJ's Avatar
RonJ will become famous soon enough
Might be worth looking for a trouble code:
Old Jan 16, 2010
MaxwellT's Avatar
Thanks. So in your diagram 7 blinks would indicate an open in the air mix control motor circuit?
If I get 12 blinks would that be a good indication that it would be the transistor? If so, would I go to the dealer to get the part? Are there other cheaper avenues?
Old Jan 16, 2010
RonJ's Avatar
Yes
A bad transistor is one possibility but not the only one. Pull the code and post it. I'll then post the appropriate troubleshooting diagram.
Old Jan 18, 2010
MaxwellT's Avatar
I went through the diagnosis and the recirculation indicator did blink 12 times pause for a second or so and 12 more blinks, etc.
What should I try next?
Old Jan 18, 2010
CraigW's Avatar
Do you have an Ohm meter ??
If so perform the continuity check on it that is shown in other threads. Something opens up on these (possibly a thermal cut off TCO. type of fuse) It may have opened.
Old Jan 18, 2010
RonJ's Avatar
Here you go:
Old Jan 18, 2010
the transistor is very easy to see. just open the glove box down like youre changing the cabin filters, and its on the left side with a plug going to it. see if you can take the plug out and make sure the metal contacts are not burnt. and if they are, clean with alcohol and grease it back up with dielectric lube. or you may just need a new transistor.
Old Jan 18, 2010
RonJ's Avatar
Best to test rather than to guess. The diagram below shows how to test the transistor, but it's wise to follow the troubleshooting guide to ensure that the bad component is identified.
Old Jan 18, 2010
yeah thats true
Old Jan 18, 2010
CraigW's Avatar
There is something on the transistor unit that opens... The best I can tell is someone had mentioned a 114 degree C. TCO. That would certainly be cheaper than the complete unit & a simple fix.
It is a pretty common issue on the 7th gens. Someone mentioned there cabin filter was plugged tight...That could certainly cause the TCO to open as the transistor relies on air flow for cooling.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
h4ldol
Apr 24, 2017 08:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
anubis62
Sep 27, 2015 12:56 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
