Belt squeaks
Belt squeaks
Ok heres the deal I have a 93 civic and my belts squeaked every once in a while and it squeaks when its wet. But I went to walmart and bought that prestone belt squeak spray. It stopped squeakin but now it makes a sound like water spraying. But theres no water sprayin. It just sounds like it. Could it just be that the spray needs to wear off or somin.
And another thing is that I just recently replaced my top radiator hose cuz it had a hole in it. And since I replaced it coolant dissappears fast. I cannot find a leak anywhere. I put some prestone radiator leak thing in my radiator to. I also air the **** out to when i changed the hose. But everyday i look at it my reserve tank is empty and when i pour coolant in it its like half of the contaner in it.
If someone can help I would appreciate it. Thanks
Re: Belt squeaks
its just the spray. but you really need to adjust the belt tension. i think they are too loose. did you bleed the coolant system after changing the hose? alot of air may still be in there. with the engine cold, take the radiator cap off, start car, and warm up to normal temp by revving to 3k rpms. turn the heater on full blast and watch what happens to coolant in the radiator. keep filling it to the top if it goes down. and watch for air bubbles coming out. once they stop, put the cap back on. you prolly just need to bleed the air and allow coolant to the heater core.
Re: Belt squeaks
Ill go adjust the belt tension. But as for the radiator the screw that is on the engine witht he top hose connected to it i let all the air out of that and the same with the radiator and filled it to the top. Now since i put the preston leak thing in i havent check it yet but hopefully that works
Re: Belt squeaks
That Prestone leak stop stuff is awful for your engine. It really does more harm than good! Just don't put any more in now that you gave the system a good flush. If you have a leak your better off to fix it than put the prestone stuff in IMO.
WaryDriver
Aug 16, 2015 11:22 AM
Ray Darvi
Aug 12, 2015 11:55 AM
WaryDriver
Aug 8, 2015 05:08 PM
Ariah J. Davis
Jul 20, 2015 07:15 AM
1khilari
Jul 9, 2015 08:12 PM
