Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Fluids
Old Oct 1, 2009
richs1000's Avatar
richs1000 is an unknown quantity at this point
Fluids
how much fluid does the tranny hold on an 02 auto, Im just draining and refilling. and how much oil does the engine hold (non v-tec)
Old Oct 1, 2009
CraigW's Avatar
Re: Fluids
ATF=3qts / Oil=3.5qts
Old Oct 1, 2009
Re: Fluids
those are all rough estimates from the service book tho. oil takes anywhere from 3-3.5 qts and its best to check the level as you are filling to avoid going above max. check it again after driving cause you may lose a bit in the new filter. trans is pretty consistent around 2.9-3.0 qts. the whole trans holds about 9 qts but only 3 will drain out.
Old Oct 1, 2009
richs1000's Avatar
Re: Fluids
Would a tranny flush be better and where should i go to get a flush?
Old Oct 2, 2009
CraigW's Avatar
Re: Fluids
^ No, just a drain and refill.
And only OEM fluid.
Old Oct 2, 2009
Re: Fluids
tranny flush is a very bad idea
sf3r8z
Apr 19, 2016 01:53 PM
Raiool
Oct 1, 2015 10:42 AM
ken4444
Sep 30, 2015 07:37 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
