emergency please help! timing belt now shaky
Rep Power: 0 emergency please help! timing belt now shaky
hi i just did my timing belt and the car ran fine while i changed coolant but it is shaky now and the engine tight comes on right away. this is not good. can somebody help?
Rep Power: 787 Re: emergency please help! timing belt now shaky
first thing to do is check the engine code and see what it says. if belt was off a tooth, car would run very rough or die. you may have accidentally damaged a sensor when you had everything apart, usually the tdc sensor.
Rep Power: 0 Re: emergency please help! timing belt now shaky
HAHAHAHA THE EMOTIONAL SWINGS!!!!
noobie alert>>>>>> I didnt push the #1 coild adapter in all the way!!! car runs great!!! sleepless night is for nothing!!!
ty gearbox i wouldnt have found it so fast without your help man. now to take it around the block
lol yeah i was relieved when you said misfire. which usually turns out to be spark plug related and not a big deal. i guess its too late, but yeah you can read codes with the car in ON position and engine OFF.
i drove the car for like 30 minutes and it runs like new. there was even a chirping sound the last 50000 miles or so that would occur during acceleration at about 2500 rpm and last till about 2800 rpm. that sound has almost vanished. theres a hint of it here and there. like a rattle meets a chirp ya know? i think it was either drive belt related or tensioner pulley related. im not sure.
anyhow im so exhausted i went and bought 12 beers and i am doing nothing the rest of the day lol
Rep Power: 229 Re: emergency please help! timing belt now shaky
lol there are bolts for the coil packs put them on!! Nice success on your job well done. You saved yourself a few hundred dollars. You should have done your alternator and ps belts while you had em off.
lol i accually did bolt them on,, plug after that i had only halfway in.
ya i did the belts too. it was pretty cool how they tension from the top i really like that feature. made it very easy.
i think i saved like a 1000 dollars!
parts
- 12$ timing belt
- 100$ motor mount
- 50$ water pump
- 30$ valve cover gasket
- 4$ lug and stud
- 45$ brake pads the good ones!
- 2$ grease
- 5$ rtv glue
- 30$ coolant
- 20$ oil and filter
- 12$ spark plugs
- 3$ anti seize
- 25$ chilton book (get this noobs! vital. you can always cross check other peops info with it and understand what has leeway and what does not.)
so about 355$ in parts. about 200$ in tool investments. with no tools i imagine about 500$ would be needed.
855 dollar investment total to get this sort of job done from a starting point of having nothing. not bad. shop still would have been more with no tools to show for it.
the whole job took 30 hours that included-
-timing belt
-water pump
-broked lugnut (torque wrench from now on. this job was a biatch.)
-drive belts
-spark plugs
-valve adjustment
-new motor mount
-oil change
-coolant flush
-tire rotation
-brake pads (greased them up good on the backs too!)
-reading time
-auto parts store time
-asking questions
-cleanup
:b ump:
mattdoc
03-14-2017 12:10 PM
