Diy brake system pullout
Going to a part pullout lot. Trying to get my hands on some disc brakes. Is there a play by picture d.I.y thread I can use(mostly to locate the bolts and cables )
Re: Diy brake system pullout
I'm assuming you are getting the rear disk brakes? Take the knuckle and everything that is on the knuckle. There will be a cable going to the caliper for the ebrake. There will be a few bolts holding the lines on. Take the brake lines as well because disk brake and drum brake lines are not interchangeable.
Good enough. The thing is that the previous owner was an idiot and swapped the f/r disc to an integra and the rest is ex civic(drums in the rear) so I hav to get th f/l lines as well
WaryDriver
23
Jul 22, 2015 07:18 PM
Youshoe
May 22, 2015 09:36 PM
