Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Opinion on cost to fix.
Old Jul 5, 2009
sp44's Avatar
sp44 is an unknown quantity at this point
Got a quote from import mechanic.
Head gasket, 600.
Oil pan gasket, 240
Sway bar link bushings, 200.
93 EX
Old Jul 5, 2009
Jp7's Avatar
Jp7
Jp7 is an unknown quantity at this point
Re: Opinion on cost to fix.
That stuff is pretty easy to do yourself. Change the timing belt while your in there.
Old Jul 5, 2009
TRIZ's Avatar
I'd do them myself, because those prices are a joke. Do the stock sway bar end links even have bushings? My aftermarket's are all metal.
Old Jul 6, 2009
sp44's Avatar
I was thinking of doing the oil pan gasket and bushings myself. The head gasket I'm a little worried about having never taking the engine apart. As far as that, how often does it need to be machined?
Old Jul 6, 2009
head gasket is reasonable, the rest are way overpriced. sway bar bushings takes 10 minutes, no more than $40 of labor. oil pan is also easy in most case, just look under there and make sure you can get to all the bolts. on some models the trans or chassis bars may need to be removed and then it gets quite crazy to do yourself.
Old Jul 6, 2009
sp44's Avatar
As long as I'm at it should I replace the radiator too? Not that expensive to do myself right? Replacements are pretty cheap. Water pump he said is fine.
Old Jul 6, 2009
well if you want, but i wouldnt bother unless the old one is actually causing a problem. whats the reason for the headgasket blowing? i think that should be the first priority to fix otherwise its just gonna blow the new gasket.
Old Jul 6, 2009
sp44's Avatar
Only thing mentioned was the seal on the radiator cap looked bad. Which is why I didn't notice the temp gauge go up. It stayed normal.
Old Jul 13, 2009
sp44's Avatar
Well got the head gasket fixed and did the oil pan gasket. Now after driving it a bit I have another oil leak! Yay! Back it goes. What's another common oil leak? Valve cover gasket was replaced
Old Jul 13, 2009
did you have all the crank and cam seals done? could also be the oil pump.
Old Jul 17, 2009
sp44's Avatar
It was the oil pan gasket. Got pinched when I put it on. But now I'm back to a coolant leak again! On the right side away from the radiator.
Stock 99
Sep 5, 2015 06:06 AM
JJ291
Sep 2, 2015 11:49 PM
ttamrekab
Aug 23, 2015 07:45 PM
cyc
Jul 22, 2015 01:14 PM
