Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
83 Civic 1500 head gasket
Old May 5, 2009
dunchan1's Avatar
dunchan1 is an unknown quantity at this point
As the Honda dealer no longer stocks head gaskets, what brand should I use for best results and WHERE can I find it?? This is a rebuilt engine that has blown head gaskets in the past. Now has head and block been trued.
Cliff
joliet421@yahoo.com
Old May 5, 2009
Re: 83 Civic 1500 head gasket
www.hondaautomotiveparts.com just get the oem one, its $43. be sure to check the old head for warpage and have it milled otherwise you will blow the new gasket too. just take it to a machine shop and tell them to inspect it.
Old May 6, 2009
dunchan1's Avatar
Gearbox: Head has been milled as has the block. This unit blew head gasket 3 different times .. last one AFTER the head was milled. We did NOT use new head bolts which some say must be done. Comments?? Radiator is good as is all circulation and water pump.
Old May 6, 2009
oh yes new head bolts are required. expensive, but the old bolts cannot be reused. also there is a very precise tightening and multiple torque sequence for those bolts, and if you hear any squeaking sound when they are going in, you have to take all the bolts off and start over again. if your car has chronic gasket blowing issues, you may even want to see if they make upgraded head STUDS for your car and buy those too. like the arp studs.
Old May 6, 2009
Old May 6, 2009
dunchan1's Avatar
Thanks Gearbox. You echo what I've find elsewhere. Expensive?? Yup, sure are. Guess there's no help for it.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
hokiedad4
Apr 30, 2015 07:18 AM
Geoff_Geoff
16
Apr 30, 2015 12:17 AM
BREADFAN
Apr 15, 2015 08:58 AM
deus-ex
Apr 13, 2015 12:29 PM
