Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Old problem returns....
Old Mar 22, 2009
number4t1's Avatar
number4t1 is an unknown quantity at this point
Have a '91 Civic. About a year and a half ago, had some ignition problems. Replaced the dizzy and that seemed to fix everything. Last summer, I noticed a few times that the car wouldn't start if it had been sitting in the sun all day, or driven and the stopped briefly. Had heard this was likely a relay or sensor problem that was common on older civics. Before I got around to fix it, temperatures cooled off and the problem went away. Kinda forgot about it until Thursday.
Drove the car to pick up my son from school and shut it off while I waited. After about 10 minutes, tried to start it again but it wouldn't. The engine turns over fine, but won't start. Came back when it was cool Friday morning to start it to get it home, but still no joy.
The ECU shows no error codes. Could this be the dizzy again, or it this more likely a relay or sensor issue? Just not sure where to start, but I need to get this car going again quickly.
Any ideas?
Old Mar 22, 2009
Re: Old problem returns....
seems like a fuel delivery problem? almost sounds like vapor lock or something.
Old Mar 22, 2009
lordhelmet's Avatar
Check the fuel pump relay.
Old Mar 22, 2009
number4t1's Avatar
I can hear the fuel pump power up when I first turn on the ignition. That is another item that I replaced along with the dizzy (although, in retrospect, I don't think it needed to be changed.)
Where is the pump relay located?
Old Mar 22, 2009
well if you hear it, the pump (and relay) is prolly fine. could be a fuel line problem. did you connect everything to the pump properly? have you measured the fuel pressure?
Old Mar 23, 2009
lordhelmet's Avatar
I'm serious about the relay. It only acts up when its hot. Its 20 bucks.
Old Apr 6, 2009
number4t1's Avatar
Hey guys! I'm back (been out of commision with the flue for a while). Still haven't gotten the car going. I checked out the fuel pump relay, and it seems to be fine (I can hear the pump power up when I turn the key to the "on" position). What should I look at next? Someone suggested the crank or cam sensor? Where is that? How do I check it? Wouldn't either of those give me an error code? I am getting no error codes on the ECU. Is there an easy way to test the distributor?
Old Apr 6, 2009
number4t1's Avatar
The pump was replaced over a year ago, and has been running fine until recently. I don't think this has anything to do with that repair. What is the easiest way to check for fuel blockage?
Old Apr 6, 2009
well get a fuel pressure gauge and see if it reads within spec. did you replace the fuel filter recently?
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
