Cold Air Intake wat to do with air temp sensor?
hi.i was just wondering where does the air temp sensor go with a new cold air intake cos it is usually inside the air filter box.all thats on the intake pipe is the outlet for the small rubber pipe to go straight to the engine but no hole to put the sensor??
Re: Cold Air Intake wat to do with air temp sensor?
There should be a hole, or else you bought a very shitty intake with .2 seconds of engineering behind it.
it should have a hole, otherwise tie the sensor to something in the engine bay so the sensor is in open air. same idea.
ORskier
May 7, 2015 04:54 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
