Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
driver side floor leak 05 ex
Old Feb 3, 2009
fvnktion's Avatar
fvnktion can only hope to improve
My driver side floor gets wet when it rains or when the car is washed. Here are few of the things I have tried to do to fix the problem with and the problem still seems to persist.
Try 1:
I lifted the car and looked at all the seams to see if there could be anything leaking in there. Anyplace that looked like a possibility i put sealed up with silicon. I used a fan to dry the carpet completely to see if it would get wet again. After the next snow storm it was just as wet as ever.
Try2:
After try 2 didn't work, I ended up taking up the floor siding panels, the foot rest and then took up the carpet. The carpet is still quite wet. There is a body plug under the carpet, which i put silicon on and replaced and a plug just above the foot rest, which i siliconed and replaced. I can't see any signs of where the water could be leaking in cracks.
I did find some sort of what looks like an air duct that comes from the driver side of the shift console and ends up sitting flat on the floor and continues under the driver seat. There is some residual water that is under it - I'm not sure if this just a convenient place to sit or if this could be where the leak is coming from??
Do you know what this black duct is?? Could it be causing the leaking of water/condensation?? How would i test this?
Thanks
File Type: jpg
Old Feb 3, 2009
CraigW's Avatar
Re: driver side floor leak 05 ex
Sounds like the rear heater duct, not likely the source of the water.
Old Feb 3, 2009
fvnktion's Avatar
I'm thinking that i will completely let everything dry out and get a hose and start spraying around to see if i see anything coming in.
Any other ideas of things to look for?
Thanks.
Old Feb 3, 2009
CraigW's Avatar
That would be a good idea to try. You may or not see dripping. Try to narrow down what area gets wet first and go up from there.
Old Feb 3, 2009
greeen01civic4d's Avatar
do u use the a/c with the window cracked or down, ac will build condensation and leak, a lot. first step would be have someone hold a hose on it, full pressure with a nozzle and look for leaks, mainly around winsheild and surrounding areas
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
ashlava71
May 16, 2015 12:54 PM
dennis123
May 3, 2015 03:14 PM
ej8
Apr 13, 2015 06:36 PM
mwwhonda
Nov 7, 2001 07:24 PM
