Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Fuel delivery
Old Dec 27, 2008
jetfixer's Avatar
jetfixer is an unknown quantity at this point
Fuel delivery
I recently inherited a 95 civic from my mother in law. Its got 250k mi and has a starting issue. Theres a relay that primes the fuel pump when key is turned to pwr. Sometimes takes 20 sec to a minute/half for the relay to energize. I think my problem is w/ the ECU but not sure. Allready swapped out relay, original is still good. I dont know much about Hondas, 1st one. Any help would be gr8.
Old Dec 27, 2008
cim's Avatar
cim
cim is an unknown quantity at this point
Re: Fuel delivery
You swapped out the relay and it is still having problems? Does the fuel pump ever turn off after running?
Some things to check (if you already have checked the relay or replaced with a known good one):
1. Check terminal 7 (to fuel pump yellow/green wire) for battery voltage right after you turn to ignition (2 second pulse). If you see voltage then there may be an intermittent open to fuel pump or problem with the fuel pump.
2. Check terminal 8 (to ECU green/yellow). It should be at ground after turning on ignition for two seconds and during start/run.
3. Check fuses
Old Dec 28, 2008
jetfixer's Avatar
Re: Fuel delivery
what terminals? do you mean on the connector for the relay?
Old Dec 28, 2008
cim's Avatar
cim
Re: Fuel delivery
yes, you'll have to backprobe them or you can verify the relay operation by itself. If you've swapped out the relay then with a good one then it might be wiring issue.
To check the wiring, with the relay removed you should see +12V on terminal 1, +12V on terminal 5 only when ignition is on, +12V on terminal 6 when starter is engaged. Disconnect the negative terminal of the battery and test for continuity (0 ohms) between terminal 2 and any ground on the chassis. Then test for continuity between terminal 8 and pin A16 on the ECU.
Old Jan 1, 2009
jetfixer's Avatar
Re: Fuel delivery
Hey thanks for the help.
Old Jan 3, 2009
estridge48's Avatar
estridge48 is an unknown quantity at this point
Re: Fuel delivery
Correct me if I'm wrong. Today's fuel injected cars usually hold pressure even if the car has been idle. Jetfixer states he has a starting problem, could this be due to a bad fuel pressure regulator or possibly a leaky fuel injector? Once the car has been running and then turned off, the fuel line should still be pressurized. Therefore, on his next start it should fire up with no problem, correct?
Old Jan 4, 2009
jetfixer's Avatar
Re: Fuel delivery
I dont think this is a fuel press issue. The purpose of the relay in question is to prime fuel press to start. The relay is working intermittently. Checked relay w/ meter, relay is good. Shot all other wires needed and found no discrepencies. ???
GritzNGravy
Aug 19, 2015 03:03 AM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
