Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Cigarette Lighter and Gauges Wont Work...
Old Aug 21, 2006
Rinkrat456's Avatar
Rinkrat456 is an unknown quantity at this point
Arrow Cigarette Lighter and Gauges Wont Work...
I recently put footwell lights in a 2000 Honda Civic 2Dr. I tapped into the cigarette lighter for a 12v source and sparked the positive and negative once before I taped off a cut wire. Now the cigarette lighter doesn't work and the gauges wont light up at night. Does anyone know of which fuse I might have blown? I looked in the manual and visually checked the interior fuse pannel but none seemed to be blown.
I also had this problem in my GMC Sonoma, same install of the lights and everything, where the gauges wouldn't light up and the cigarette lighter wouldn't supply power.
Does anyone know which fuse to check or is there another problem that can be fixed/replaced? Thanks all in advanced!
Old Aug 21, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
just look on the fuse box cover...... or in the owners manual they'll have a list.. it may be labeled as illum or something like that.....
Old Aug 21, 2006
Rinkrat456's Avatar
While this is open
While I've got this thread open, I'm sure someone knows what the speaker sizes are front and back.
Are they 6.5" in the doors and 6x9's in the trunk/rear?
Thanks again!
Old Aug 22, 2006
Rinkrat456's Avatar
Just to update, I had some time with the car last night and noticed two fuses were blown. One controlled the cigarette socket and the other fixed a beeping alarm when the keys were forgotten in the ignition.
I still can't get the gauges to light up. There's a fuse that says Instrument Illumination. That fuse is good but the gauges wont light up at night.
Any ideas?
Old Aug 23, 2006
pico's Avatar
pico is an unknown quantity at this point
Maybe the bulb that lights up the gauges is burned out?????
Old Aug 24, 2006
05blkrs's Avatar
turn up the dimmer switch..... i know it's common sense but everyone does it at some point.. ast least most ppl... imo
Old Aug 24, 2006
Rinkrat456's Avatar
Dimmer switch is all the way up. Any other ideas?
Old Aug 25, 2006
05blkrs's Avatar
idk then... check the cluster for a good connection.. btw they should, SHOULD be 5 1/4 in the doors.. and i believe the 6X9 is right for the rear deck...
Old Aug 25, 2006
Rinkrat456's Avatar
Thanks 05blkrs.
Actually I'm pretty sure I figured out what it is. I didn't think mentioning I just installed a Pioneer deck would be of any concern. The wiring harness for the deck has an illumination wire (orange with white stripe) and I hooked that up to the existing gauge illumination wire back there. I'm leaning more towards that since it is the only thing that could constantly ground out the power going to the gauges.
5.25" in the doors.
6x9's in the rear/trunk?
Old Aug 25, 2006
05blkrs's Avatar
in that case just adjust your dimmer settings on the radio...
Old Aug 26, 2006
Rinkrat456's Avatar
It's not the radio. I cut off the illumination wires simply because they're not needed. I checked every fuse in the fuse pannel with a green light tester, even checked every fuse under the hood in that sub pannel. All were good, even the Instrument Illumination fuse. I took apart the gauge assembly and checked every bulb in the gauge cluster. All were good.
Im at a loss for what to do next. I'm about ready to throw in the towel and take it to a Honda dealer.
Anything else I might have overlooked?
Old Aug 26, 2006
05blkrs's Avatar
before you do that go into the fuse panel w/ a 12 volt test light.. you're losing power somewhere.. try to track at what point you're losing power.. turn the lgihts on and the dimmer all the way up, and test the fuse for current.. on both sides.. sometimes it can look fine but be blown.. jsut a thought.. where are you located? not in texas i'm guessing.. otherwise i'd look at it for you...
Old Aug 27, 2006
Rinkrat456's Avatar
Minnesota.
I don't know how you Honda Civic owners fit under the dash. There's no room under there at all!
Could it be a relay?
Old Aug 30, 2006
Rinkrat456's Avatar
Just to follow up. I brought it into the dealership and they found it was the dimmer switch. Not that I didn't have it turned up, but instead that it was fried completely. Funny I didn't catch that either because I took that pannel apart. Apparently it was black from being grounded out.
Part is $65 and car is all good now.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
Bricoleur
Sep 9, 2015 12:23 PM
