Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Engine Light
Old Jun 27, 2006
ryanjcroteau's Avatar
ryanjcroteau is an unknown quantity at this point
Engine Light
Hello, a few weeks ago my engine light came on in my 98 civic lx. If I put the clutch in when either taking a turn or decellerating for any period of time, the car stalls - i have to pop it into neutral immediately and although it idles very very weak, the car does not stall. The car always runs strong for the first few minutes of driving, but when it heats up, the stalling issue begins. I have also noticed as of late a noise that almost sounds like static electricity (tick....... tick..... tick) behind the dash.
So far I have changed the distributor cap, change the plugs and wires, changed the fuel filter, and cleaned the fuel injection system - while all have improved performance to some degree, none have gotten the engine light to go off or solved the stalling problem - any ideas??
Old Jun 27, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
sounds like the ever so common ignitor problem.. though i dont know where it is located in that car...
Old Jun 27, 2006
my bad, I actually punched in my vin on honda.com and saw that i was eligible for a new ignitor under the recall - so I took it in and got it replaced last friday, i should have remembered - i posted this AM before coffee
Old Jun 27, 2006
05blkrs's Avatar
man i'd have to be there to see it then to be able to help.. i dont even drive a honda.. i just moderate and try to help out where i can... but i noticed a lot of ppl have been having problems w/ the ignitors
Old Jun 27, 2006
that reminds me
if you are having the problem with the ignitor, you should go onto honda and register, the ignitor costs about 200 bucks in most places, when i put my vin in, i saw that my 98 was covered by a recall in 2001, i called the dealership, gave them my vin, and they took the car and put a new ignitor in it for nothing.
Old Jun 27, 2006
CharlieLink's Avatar
CharlieLink is an unknown quantity at this point
Ground cable
If you had a carburetor, I'd check the float level...
Back to the recent likelihood.
Check your ground strap cable between the engine and the body. If this is not a perfect ground, it will prevent the voltage from peaking sufficiently to fire the sparkplugs.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
Flipg123
May 8, 2015 01:15 PM
tylerginevan
Apr 27, 2015 12:29 PM
