Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Skunk 2 Throttle Body
Old May 14, 2006
green98ex's Avatar
green98ex is an unknown quantity at this point
I installed a Skunk 2 60mm throttle body today on my 98 ex 5spd. Now, my car is idling at about 1,200 rpm (it was at @700), the rpms drop SLOWLY when I let off the gas, and occasionally when I go past about 2500 rpm it will get stuck there until I put my foot under the gas pedal and pull it back up. I did notice, however, that the metal part that the TPS plugs into on the skunk 2 unit was in a different position than the one on the stock t/b (the piece on the inside that attaches to the other metal piece, the second metal piece being the one that you attach the throttle cable to..but I assumed this was normal...have tried adjusting the idle screw some, as well as resetting the ECU (I was told by a friend that this is done by disconnecting the battery and waiting 5 mins, then plugging it back up; the ECU is then supposed to "adjust itself" to the new idle position)....I'd really like to get this taken care of. The car is still drivable, and other than those problems I'm pretty pleased with the t/b. Any info would be GREATLY appreciated.
Old May 14, 2006
CG99's Avatar
CG99 is an unknown quantity at this point
Let me get this straight.. did you adjust the TPS at all yet or not?
Old May 15, 2006
05blkrs's Avatar
05blkrs is an unknown quantity at this point
sounds to me like the throttle return spring isn't set up right.. once that is fixed, it will fix the throttle sticking.. also make sure you didn't over tighten the screws when atatching the throttle cable.. that will fix everything but the high idle.. adjusting the screw will help some but that may be a tps problem.. contakt skunk 2 and assure that this tb is made for your year and engine application.. if not, buying the appropriate tps (from the car the tb was meant for) will probably help
Old Oct 4, 2006
DriftKing77's Avatar
DriftKing77 is an unknown quantity at this point
Where and how much was the throttle body....cause i am looking to get one....for my 98 ex 5 spd.
Old Oct 4, 2006
Wadely's Avatar
Wadely is an unknown quantity at this point
Showstoppersusa.com Usually Has All Of Them That Are Available For The Best Pricing That Ive Found
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
Bruce2
Sep 27, 2015 08:45 PM
2.0.0.2
Sep 14, 2015 06:38 PM
Bricoleur
Sep 9, 2015 12:30 PM
