Reasons to use (or not) Honda ATF?
Old Jan 26, 2019
prr's Avatar
prr
prr is an unknown quantity at this point
I will be doing a 3 quart drain & fill with my 98 Civic automatic. I have read online, people having great results with Valvoline Maxlife ATF, and it is available a lot cheaper than the $8/qt Genuine Honda DW-1.
Is there any benefit to using the Honda fluid? If there is a reason to use the Honda fluids, I can buy the more expensive stuff for a drain & fill every 30K...
Old Jan 26, 2019
Re: Reasons to use (or not) Honda ATF?
Have you done this on this car before? What fluid was used then?
IMO no matter what fluid you use, 30k (or less) service intervals are still a good thing
Old Jan 26, 2019
prr's Avatar
prr
Never done it on this car before, but my mechanic did it about 30K ago--a flush, which used 12 quarts. I checked the fluid earlier today, and it was definitely pink, although a kind of dirty pink.
I think I'll just do a simple drain & fill every 30K, which removes almost half of the fluid IIRC (I just found a chart in my manual that gives the precise amounts for drains as well as complete flushes, but of course I can't locate that page now). That should be good, instead of doing a complete flush every 90K. Or would you recommend 3x drain & fills every 30K?
Right now I'm really leaning towards Maxlife. It is also doing well in Toyotas, so I can save money by not having to buy two different OEM fluids.
Old Jan 26, 2019
At the shop we recommend drain and fill (single) every 30k as the usual routine service.
At the shop we typically try to do the 9-12 quart flush when one has been neglected, has unknown or contaminated fluid, has a problem (such as tcc shudder), instructed as per service information, and maybe a couple more specific reasons
My personal/family Hondas get ATF more often than that lol
Old Jan 26, 2019
prr's Avatar
prr
Yeah, I remember you saying something about every other oil change....
Hey since I got your ear, I have a Sienna that has NEVER had an ATF drain & fill, in 160K. I took it to my mechanic, who warned me that since the fluid was black, that there might be a chance of problems developing if he were to do a fil or flush (since he did a flush on my Civic, this was probably what he had in mind).
I would like to do a simple drain & fill with my Sienna as well (again--160K without one). In order to not disturb any gunk that might be residing in the AFT paths, should I do 3x drain & fill, but do them a week or so apart from each other? would this be the gentlest way to change out most of my old cruddy fluid, without harming the transmission itself? Or is there any other way you'd recommend doing this?
Old Jan 26, 2019
Simple fluid service with correct fluid is the best thing you can do for it IMPO.
No additives, no chemicals,
Do it as many times as you feel comfortable
Fresh clean correct manufacturer specified fluid or equivalent should not hurt a transmission regardless of mileage IMO
Some people don't think about trans service (or anything car related) until they notice something wrong,
So they get it serviced and it doesn't solve anything, because it was already broken before the service.
Then they blame the fluid service and the shop that did it (sue because they believe they deserve a new transmission of course),........
This is why many JizzyLubes make you sign a waiver if your trans or car has lots of miles without service
IMO this is where the wives' tale "don't change the fluid" comes from
Old Jan 26, 2019
prr's Avatar
prr
Thanks a lot!
OK when I'm done with the Civic, I'll get on the Sienna. I wasn't going to use any additional additives.
Thanks again!
Old Nov 16, 2019
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
totally agree with You ezone!
Old Jan 8, 2020
chuffsy's Avatar
chuffsy is an unknown quantity at this point
You might have done the drain and fill already on your Sienna and the approach you mentioned is the same that I would do if mine were at that mileage without any prior changes. I am at 175 k miles now on my 06 Sienna Le and I did a flush once at 60 k , after that its been drain and fill three times each event.
For my 2010 Civic I do a drain and fill event every 25-30k miles. I use only genuine toyota nd honda fluids
Old Feb 4, 2020
digger's Avatar
digger is an unknown quantity at this point
You haven't mentioned changing the transmission filter? Better do some research on that. LOL
Old Feb 4, 2020
Colin42's Avatar
Can only change the filter by removing the trans and splitting the case.... Better do some research
grandnexus
Transmission DIY
Oct 4, 2019 08:49 AM
Doug Lassiter
23
Feb 23, 2015 06:16 PM
usvpn
May 27, 2012 07:28 PM
abchilln
16
Mar 31, 2010 04:31 PM
nixhex
Aug 8, 2009 08:46 AM
