Coolant Reservoir Markings
I have an 02 Civic EX and it is impossible to see the coolant level inside the reservoir. I can see the molded indentions on the reservoir that read min (minimum) and max but with a 50 50 mix of coolant and water I can't even see the coolant. I have been getting a reading the only way possible with a flexible rod that I stick inside into the coolant reservoir to get it wet then guess at where the coolant level is. My question is what do you do that I don't or is everyone experiencing the same problem with reading the coolant level? Thanks!!!
p.s. My very First post!
Re: Coolant Reservoir Markings
Yeah, they kinda suck to see.
I use a strong flashlight.
Take the cap off the reservoir and shine it inside if necessary.
Wiggle the reservoir, see the liquid move.
No sense in pulling a battery out, this is supposed to be simple.
I quess my reservoir might be a different type of plastic because shining a maglight inside don't help. I will keep my trusted rod handy and continue to wonder why the Japenese designed it this way. Thanks to you all!!!
I have the same issue with my 2006 Civic, so I usually stick a flexible reading light thingie down there so I can get a better look. The reservoir is just way too opaque to see through otherwise...
styles234
21
Nov 19, 2019 07:23 AM
raymondxcho
Sep 29, 2015 09:00 PM
