Castrol Magnetic 10-40?
Old Aug 23, 2010
usvpn's Avatar
usvpn is an unknown quantity at this point
Is Castrol Magnetic 10-40 good for Civic 2009? I live in Dubai, so it's always warm or hot!
Old Aug 23, 2010
02civicsi02's Avatar
Low and slow!
Re: Castrol Magnetic 10-40?
If it is mostly hot where you are you should run 5w30. Castrol is good oil to use.
Old Aug 23, 2010
yeah no need to use anything thicker than 5w30. it normally is between 90-100 here all summer and i have no problems.
Old Aug 23, 2010
kbook's Avatar
kbook has a spectacular aura aboutkbook has a spectacular aura aboutkbook has a spectacular aura about
They stated the oil weight in the manual differently. For example, Thai people use 10W-30 sometimes 10W-40 for many generations of civics. Some even use 0W-50
I guess there should be no problem.
Old Aug 23, 2010
what kind of engine is this?
Old Aug 23, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
So... the gas in Dubai, like 10 cents/liter?
Old Aug 23, 2010
D17cancun's Avatar
D17cancun is an unknown quantity at this point
THATS EXCELLENT CHOICE MAN
ACTUALLY I WAS READING SOME STUFF FROM CASTROL MEXICO
BUT I THINK YOU WILL NOT UNDERSTAND EVERYTHING LOL!!!
HERE IS THE LINK IN ENGLISH WHERE YOU CAN CLARIFY THOSE DOUBTS ABOUT THE
5W 40 MYTHS OK??????????
http://www.castrol.com/castrol/secti...tentId=7027681
Old Aug 23, 2010
D17cancun's Avatar
THIS IS THE ALL EXPLANATION ABOUT WICH OIL YOU SHOULD USE OR NOT BUT YOU KNOW WAHT IS IN SPANISH
IN THE US WEBSITE FROM CASTROL IS NOT THERE ONLY IN MEXICOS ONE
Existe gran confusión y mitos alrededor de estas siglas en los Aceites de motor.
Los aceites multigrado son desarrollados para trabajar en aplicaciones donde existen cambios de temperatura considerables, por ejemplo, en algunos lugares de nuestro país las temperaturas son de –8°C en el invierno y de 40°C en el verano.
Hoy día, los aceites monogrados han sido desplazados paulatinamente por los multigrados alrededor del mundo, los aceites monogrados se utilizan aún en aplicaciones como motores de competencia, equipo industrial que opera 100% en aplicaciones de alta temperatura y condiciones especiales de diseño de motores que no permiten el uso de un multigrado.
Para el caso de un aceite 20W 50, mucha gente piensa que el 20W es el grado del aceite para bajas temperaturas y el 50 es el grado para altas temperaturas, aunque hay cierta lógica, también existen grandes diferencias, sí esto fuera verdad, un aceite 20W 50 sería grado 20 en baja temperatura y 50 en alta temperatura, eso significa que este aceite "aumentaría su viscosidad" con el cambio de la temperatura, lo cuál físicamente no ocurre. La realidad es que el aceite 20W 50 tiene mayor viscosidad a bajas temperaturas y conforme se calienta va perdiendo viscosidad.
El número 20W se refiere a la facilidad con la que el aceite puede ser "bombeado" en bajas temperaturas, mientras más bajo sea el número "W", mejores serán sus propiedades de fluidez y facilitara el arranque del motor a bajas temperaturas. La "W" significa Winter - Invierno.
Un aceite 5W 50 es mejor que un 20W 50 en arranque a bajas temperaturas, ese es el significado real del primer número "Facilidad de arranque a bajas temperaturas", el segundo término es el grado de viscosidad del aceite en las temperaturas normales de operación del motor y se determina por la viscosidad cinemática del aceite a 100°C.
Una vez que el motor arrancó y el motor llega a su temperatura normal de operación, el aceite trabaja como un grado SAE 50, esta es la viscosidad con la que se protege al motor la mayor parte del tiempo, la ventaja de los aceites multigrados es su flexibilidad para proteger al motor en el arranque, con una viscosidad baja y que permite que el aceite llegue rápido a las partes altas del motor, para protegerlo contra el desgaste y posteriormente que sostenga una viscosidad correcta para el tiempo que opera en condiciones "normales" de temperatura que son reguladas por el sistema de refrigeración (enfriamiento) del motor.
Para lograr este efecto, se adiciona al aceite un aditivo llamado mejorador del índice de viscosidad en la formulación del aceite. Este polímero se expande conforme la temperatura se incrementa, compensando en algo el efecto de adelgazamiento que se origina por el incremento de la temperatura del aceite.
Recuerde que el aceite por naturaleza se adelgazará con la temperatura, lo importante en los multigrados es CUANTO se adelgaza, el aditivo mejorador de IV (índice de viscosidad) reduce la acción de adelgazamiento.
Los motores modernos requieren de un aceite con excelentes características de fluidez a bajas temperaturas y que mantengan la viscosidad adecuada en las temperaturas normales de operación, para proteger eficientemente al motor ayudándolo a extender su vida útil.
Old Aug 24, 2010
usvpn's Avatar
Hi and thank you everybody
gearbox: It's 1.8.
jsmithe2010: Gas is cheap here, however it still depends.
So I finally couldn't find which one to use in hot weather
Sorry but English is not my primary language, so you recommend 10-40 or 20-50?
Old Aug 24, 2010
Low and slow!
5w30
Old Aug 24, 2010
do you have the owner manual? it should recommend which oil is best for the engine.
Old Aug 30, 2010
Silver02EX's Avatar
Silver02EX is an unknown quantity at this point
Use what your owner's manual calls for. If it calls for 10w40 I would use 10w40.
Old Aug 30, 2010
sl33pyriceboi's Avatar
^but he uses the same engine as all the other 8th gen civics. using 5w30 is fine.a
JetsterDajet
52
May 8, 2016 12:11 AM
civic02ex
19
Mar 29, 2003 01:59 AM
vtecharry
Mar 4, 2003 01:39 AM
JoeyP
Jan 21, 2003 02:40 PM
