New Member with Question
Old Aug 31, 2010
moon153's Avatar
moon153 is an unknown quantity at this point
I just bought my daughter a 1997 Civic 4-door. Her gas guage never stays still, moves all the time. Talked to a couple of shops and they say the fuel pump needs to be replaced. Is that correct? If the fuel pump does need to be replaced, is it a easy fix?
Thanks
Old Aug 31, 2010
Re: New Member with Question
if the car drives fine, chances are there is no problem with the pump. usually gas gauge issues are a result of the fuel sending unit going bad, or the gauge cluster itself.
Old Aug 31, 2010
jsmithe2010's Avatar
jsmithe2010 is an unknown quantity at this point
Both shops gave u the same answer uh? They must have the same BP playbook! If ur lucky, it's just a loose plug, either at the cluster's end or the tank's end. The sending unit can be a bit troublesome to replace depending how ez to get to. None of which is fatal if daughter remembers to fill up regularly.
honda200192
Suspension
Oct 27, 2019 12:23 PM
amrhamed
Jun 1, 2015 08:08 AM
viper775
Dec 9, 2001 10:52 PM
