rust removal
Old Aug 1, 2010
MartinL's Avatar
MartinL will become famous soon enoughMartinL will become famous soon enough
rust removal
Hey I just wanted to know what is the best way you guys remove rust from your civics? I'm about to sand it off and respray it but I'm weary because this "honda civic red" paint does not look very similar to my red. All the rest is surface so sanding and painting over should work?
Insight before I do something crazy please
Old Aug 2, 2010
MindBomber's Avatar
Live for the Twisties
Re: rust removal
The paint on your civic has had years to slowly oxidize, if you spray your car with brand new paint will stand out like a sore thumb. My suggestion would be either replace the body panel with junk yard panels, because the paint will already have faded or just wait until you can afford to paint the whole car.
Rusty Panels>Patchy Colors
Old Aug 2, 2010
02civicsi02's Avatar
Low and slow!
Re: rust removal
Where is the rust at and how bad is it. If its not that bad then you can just grind it away and then paint it. If its really bad then you will have to cut it out and replace the piece with anoter weld it on and sand and paint.
Old Aug 2, 2010
cmiller_01ex's Avatar
cmiller_01ex has a spectacular aura aboutcmiller_01ex has a spectacular aura about
Re: rust removal
honestly i think i would take care of the rust now. i'd sand it down and prime it. and if i couldnt paint it just leave it till you collect the money to paint it.
Old Aug 2, 2010
lazlong's Avatar
Re: rust removal
Yeah, stop the rust now.
Old Sep 10, 2010
MartinL's Avatar
Re: rust removal
Yeah there is some rust on the passenger front side of the car very small but I want to get rid of it as a preventative measure. Also on the passenger rear wheel there is some rust that has gotten through. I am thinking about getting the whole car repainted but this will not fix that rust problem.
Old Sep 10, 2010
Low and slow!
Re: rust removal
Here is your solution to the problem. Grind the rust away, put bondo on it and paint it.
Old Sep 11, 2010
Re: rust removal
if it aint a dent he wouldnt need bondo. but he deff needs to get rid of it. just take you a can of 2 dollar spray primer sand it down with like 100 gritt sand paper and spray the primer on it.
jpandjf
Aug 3, 2015 05:02 PM
greenbackz
Jul 30, 2015 12:04 AM
DerbyDad03
Jul 27, 2015 11:34 AM
Brandon Vlasak
Jul 25, 2015 07:25 PM
suburbanite
Jul 17, 2015 03:05 PM
