change timing belt already?
Rep Power: 234 change timing belt already?
I just brought my 2004 civic to Honda the other day for routine maintenance and the guy came back saying that it's almost time to replace my timing belt. He said by November I should do it and quoted me about $550. Does this sound about right?
I'll be making my last payment on a 6yr finance in December, so I was wondering if they're trying to just get money out of me considering my warranty will be up too and I won't have much reason to go there.
Re: change timing belt already?
$550 is a decent price. I'm sure independent shops may do it for slightly less. Take into consideration the kit costs around $150-$190. The remaining difference is purely labor costs.
I plan on doing mine this weekend and it'll most likely take the whole weekend.
Low and slow!
1 Post
Rep Power: 190 Re: change timing belt already?
That price seems bout right for them to change the timing belt. And the service manual for your car tells you to do a timing belt at like 110k or like what 7 yrs I think. So ya its bout that time. A timing belt is really not hard, all you have to know is to set cylinder 1 to TDC and have all the marks line up if you have them. Put the belt on and put evertything back together though you need to have the water pump and the tensioner changed as well.
And the timing belt is there for a reason. The timing belt keeps all of the internals going at the same pace and keeping them in time. If the belt breaks then those internals can not stay in pace and start going out of wack and then you have big problems.
Rep Power: 234 Re: change timing belt already?
I'm aware of the importance of a timing belt and I have a basic understanding of its function.
My car has 68,000 miles, and is a 2004, so it's 6yrs old. He said by November, so I figure he's estimating around 70,000.
It sounds like base on it's mileage you're not too keen on changing the timing belt but the fact that it's a 6 yr old car you're considering it.
Tough choice.
Personally, I'd drive it till it's around 85K. I have over 144K miles and am replacing mine. And my car is 12 yrs old. But the original owner couldn't remember if the timing belt was ever changed or not. So, I may be losing money or I am not. It's a gamble but a safe one at that.
Tough choice.
Rep Power: 0 Re: change timing belt already?
Chains dont need replacing unless they become defective. Ive had and seen many toyotas with 220k + miles easily.
jameslinkinpark: Where are you located? My 04 has 80k on it, just ordered the kit. If you are in the nj tri-state area and want to stop by I can help you out.
mattdoc
03-14-2017 12:10 PM
Supramk3
05-11-2015 07:55 PM
