Intermittent Check Oil Light on '96 Civic
Old Apr 23, 2010
ventura77's Avatar
ventura77 is an unknown quantity at this point
Hi,
I have a '96 Civic DX 166k miles and my check oil light flicker for a split second when i start the car with "cold" (not really cold just not used it for say overnight) engine. When starting the car warm it doesn't show such behavior.
I just got the car and will have it for a month or so. The oil level is fine and doesn't leak or get less by the time. I suspect the oil change was done 10-15k miles ago. So i am suspecting either the oil should be change or the oil pump is failing on me. Or it it a normal behavior?
All comment appreciated!
Old Apr 23, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: Intermittent Check Oil Light on '96 Civic
uh well, 10 to 15k miles on a car with 166k miles on a single oil change is a bit much. i suggest you change it now. even if it doesn't fix the problem, it's still a good idea.
Old Apr 23, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
change the damn oil! stat! it is probably like tar by this point.
you're supposed to get it changed every 3-5k miles if I remember correctly (I use kms.... so yeah.)
Old Apr 23, 2010
ventura77's Avatar
I have no ways to lift the car just by the jack. Should i do the oil change by myself? I'm fairly good technical guy. Or better take it to some shop? How much i can expect to pay for oil change?
thx
Old Apr 23, 2010
Awjvail's Avatar
like $30-40 at a shop for an oil change.
It doesn't really matter.. if you want to save yourself the money and embarrassment of taking a car that hasn't had its oil changed in 15,000 miles in then go ahead and do it yourself. If you want to save the time, take it to the shop.
Old Apr 23, 2010
HLC's Avatar
HLC
DIY, undo the cap on top of the engine, put catch pan under the oil pan, undo drain bolt. let drain. put drain bolt back on, fill with oil, put cap back on.
or 30$ at jiffy lube and they'll check/fill ur other fluids too i think.
Xuhme
21
Aug 7, 2023 03:40 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
SSMatey
Apr 13, 2015 06:09 PM
bahena08
Apr 11, 2015 05:09 PM
