idleing problems
Old Jun 2, 2009
thegills814's Avatar
thegills814 is an unknown quantity at this point
idleing problems
I have a 96 DX and when you start it it idles fine for a min or 2 but then revs up high then low then high then low it doesn't stop. Doesn't effect driving, but embarrassing at stop lights, everyone thinks I want to race LOL what is it? and how much will it cost?
Old Jun 2, 2009
utahbmxer's Avatar
utahbmxer is an unknown quantity at this point
Re: idleing problems
This is most likely your Idle Air Control Valve. (a valve that controls the air flow for idle, since the throttle body is closed off) Something like the sensor or motor going out/malfunctioning. I had a a '93 dodge colt that did this at stop lights too, you feel real silly.
You may be able to remove it and clean it, but I bet it just needs a new one.
Good Luck
Old Jun 2, 2009
Thank you, i will check it out.
Old Jun 12, 2009
98sLicKvIc's Avatar
98sLicKvIc is an unknown quantity at this point
i had this problem after i changed by timing belt on my 98EX, i tried to set the idle at .9 and whenever i stopped at a light or whatever it either stuck at 2 or rose and fell between 1 and 2 RPMs.
Try maybe adjusting your timing?
Old Jun 12, 2009
04 Honda Civic's Avatar
Idle contol valve or O2 sensors. Do you got a CEL?
TXcivic2001ex
Air Conditioning
23
Jul 20, 2020 07:27 AM
crowtoo
May 11, 2015 06:50 PM
jakeconnor
May 5, 2015 07:30 AM
vtechcivic
Apr 21, 2015 06:58 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
