Bad gas...Misfiring cylinder + Injectors replacements
Old Jan 14, 2009
draker777's Avatar
draker777 is an unknown quantity at this point
Wink Bad gas...Misfiring cylinder + Injectors replacements
Well I am busting my head at the steering wheel when that orange check engine start flashing and the car looking like if it was on its last mile...
So there is what I got...
misfire on cylinder 4
misfire on cylinder 3
missfir on cylinder 2
Lets call it multiple miss firing on different cylinder...
The car barely made it to the dealership on one cylinder... let say I would rather call CAA to have it towed... But I'm just so stubborn...
As I didnt know what was wrong with the car and haven't done any diagnosis ... I was wondering if some bad gas would be the origin of my problem and at the same time I'm thinking heum.... did I ever change that f...ckin fuel filter since I got that civic... Just assuming or questionning myself about it is already answering this question on my own... ( damit ) so
What do you guys think about my diagonosis of my little problem...
Fuel filter----- gone wrong or done to be change
Leading to injection of crap to the fuel rail and clogging the injector leading to some misfiring.
So up to that point... have to change the fuel filter + injector + cleeanflow down the fuel tank if water formation downthere.... While I am there better have a look at a new set of sparks plug considering these are probably gone wrong with the **** being injected.
Old Jan 15, 2009
Re: Bad gas...Misfiring cylinder + Injectors replacements
check the plugs first, then check the fuel pressure, then the injectors.
Old Jan 15, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
what year car and what spark plugs do you have in it
Old Jan 15, 2009
jd03si's Avatar
jd03si is an unknown quantity at this point
before you start throwing parts at it check valve lash adjustments and compression. i had to replace a burned exhaust valve on my k20a3 because the guy i bought the car from never had valve adjustment which caused a misfire on that cylinder along with multiple misfire code. long story short a little pm goes a long way.
Old Jan 15, 2009
drunkenmagnum's Avatar
Sounds like plugs. Had the exact problem and took like $5 and 10min to fix.
GolNat
Sep 10, 2015 08:25 PM
Supramk3
May 11, 2015 07:55 PM
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
