Is stalling a cause of bad alternator?
Old Sep 28, 2007
gameboi499's Avatar
gameboi499 is an unknown quantity at this point
With a bad alternator, you don't only have problems with starting the engine, but you also have problems with stalling right? This morning, while I was driving, the car suddenly stalled. I hit the gas, but the car won't go above 20mph. I pulled over, turned off the engine, then started it again. The engine turned over and the car did fire. But I kept having the same problem with stalling. Luckily, I was able to make it home. This is definitely caused by a bad alternator right? Is there a DIY on changing the alternator? I have a 01 ex by the way.
Old Sep 28, 2007
Re: Is stalling a cause of bad alternator?
possibly. have the charging system checked. usually the battery light comes on if the alternator isnt making enough power. otherwise you need to clean out the air intake system and IAC valve on the throttle body.
Old Sep 28, 2007
gameboi499's Avatar
if the alternator is dead, can the car still fire? initially it can still fire right? because the battery is still storing enough charges right? approximately how long after the alternator is dead when the car can't start anymore?
Old Sep 28, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
i went for 3 days on a dead alternator... soooo... depends how much power u are using such as radio and headlights
Old Sep 29, 2007
7thgen.nick's Avatar
7thgen.nick has a spectacular aura about7thgen.nick has a spectacular aura about
a while back when i did not give a **** about my car... sigh.. i didnt change the oil for like 8k miles... hah. suffering now none the les... but, i did have that same problem.. changed the oil, and it fixed it.
when was your last change? did you change the filter as well?
Cyborg Ninja
20
Jul 11, 2022 03:44 PM
beantech
Jun 15, 2015 07:09 PM
crowtoo
May 11, 2015 06:50 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
pincookie1
May 4, 2015 12:22 PM
