What is gapping and electrode in spark plugs?
I just changed my spark plugs, and luckily I didn't have to gap the plugs. But what exactly is gapping? What is electrode? Are the two related? Also I still keep the old plugs. How do you measure the electrode? By looking at the old plugs?
Re: What is gapping and electrode in spark plugs?
ok, if you dont know what gapping is, how do you know you didnt have to gap your new plugs? were they platinum plugs? if theyre platinum and youre n/a youre wasting your money. also, never gap a platinum plug. you will break the **** out of it. anyway, back to topic. gap is the distance between the 2 electrodes often measured in thousandths of an inch. electrodes are the 2 parts of a plug that go into the combustion chamber and the spark jumps between them. to measure an electrode, you must first know the gap of the plug when it was installed, which unless you are the one who installed it, you cant guarantee that is was gapped right when it was put in. when you pull the plug, measure the old plug gap and that will tell you how much the plug wore away. having the gap off on even one plug can cause a lopey idle. that answer your questions?
http://www.tooldiscounter.com/ItemDi...le&kw=LIS67800
If you are feeling really fancy, head over to Sears and buy yourself some feeler gauges. They come in different size ranges so make sure you buy the set that is has the size you need included.
http://en.wikipedia.org/wiki/Feeler_gauge
to clear up your question about measuring the old plug gap, youre not measuring how far the electrode has moved. it wears away and thats what youre measuring. after they wear away so far, the weaker sparks from most factory ignition systems have a hard time making the jump between the widened gap. then you end up with misfires.
Tommy Cohen
Jul 22, 2015 07:54 PM
1khilari
Jul 9, 2015 08:12 PM
CivicsClass101
Jul 9, 2015 11:14 AM
