First Timer
Old Dec 26, 2006
TrAvIs 05's Avatar
TrAvIs 05 is an unknown quantity at this point
First Timer
Ok, so since i've had my civic it's been almost 3,000 miles (right now its just above 71,000) so what is everything i will need to change? Also, should i do it myself (never had before but i probably could) or should i just bring it to a place that will do it for $30? I have no idea what the place used that i got it from and it didn't come with a manual. Oil, trans fluid, etc?
Old Dec 27, 2006
sl33pyriceboi's Avatar
you obviously needa take it to the place....dont do it urself...cuz u kinda dont know what ur talking about...
if ur vic only has 7k miles, all u need is an oil change....its pretty easy, but its a challenge to people who dont know what they're talking about.... =]
trans. fluid is not needed to be changed.
Old Dec 27, 2006
TrAvIs 05's Avatar
My bad, i forgot a zero... haha.
Old Dec 27, 2006
streetglower's Avatar
at $71,000, $30 isnt going to cut it. an oil change to begine with $10-$15.
tranny fluid change with honda ATF ( or manaul fluid if a manaul) $20-$40.
air filter $10
spark plugs (good ones) $30-$40.
brake fluid change $5 yourself with help or $30-$100 for a shop.
basically if you do stuff yourself you pay the cost of the fluid. a shop is going to charge the labor. but if you take it in, look to spend at least $100.
Old Dec 27, 2006
^also check ur brake pads
Old Dec 27, 2006
TrAvIs 05's Avatar
Also, i just bought it from a dealer and it was fully serviced (new tires and everything) so that's almost 3k on all new stuff so would i still need spark plugs, brake pads, brake fluid, etc?
Old Dec 27, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
if you bought it from a dealer then it should be fine(as long as they did their job maintaining the car)
Old Dec 27, 2006
never trust the dealer. I say that when buying a used car. I have purchased a used car before and 2 days after I bought it checked the tranny fluid and it was black. not everything is done at the dealer.
I doubt they did the plugs, check the brakes, look at the brake fluid. usually you can tell if its been done.
Boosted2k2
Engine Swaps
24
Sep 30, 2004 02:32 PM
Catalyst
Engine Swaps
45
Jan 30, 2004 12:52 AM
prototype
Engine Swaps
Oct 15, 2003 02:09 PM
Deejai35
Aug 15, 2003 05:23 PM
hothondacivic02
May 20, 2003 11:33 AM
