Timing belt and fliuds change???
Old Sep 19, 2005
MeguiarsEM's Avatar
MeguiarsEM is an unknown quantity at this point
Does anyone know after how many miles do you change your timing belt and fluids (tranny,radiator/coolants, etc....). Info would be greatly appriciated
Old Sep 19, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
u should search. it has been coverd many times b4. I wanna say timing belt at 90 or 110k miles
Old Sep 19, 2005
Michalo187's Avatar
Abortion Survivor
110 for everything i think except your oil thats every 3000
Old Sep 19, 2005
20civic01's Avatar
20civic01 is an unknown quantity at this point
i just called honda today about the timing belt. i first got a thing in the mail saying 70k. and then another dealer said 80. and then the last two times, i got 90k-100k. so...i'm thinking that 90-100k is the correct one, but it could be they were just trying to get money from me as those notices came as i reached those mileage points.
Old Sep 20, 2005
streetglower's Avatar
the timing belt should be changed at 110K miles or earlier if you drive in severe conditions or when the belt wears out. As for the coolant, they say it will go 100K miles, but I changed it at 50K and then again at 90K, thats because I drive alot. The tranny fluid I would recommend every 20K miles or so.
Old Sep 20, 2005
Jrfish007's Avatar
And tranny fluid every 20k or so.
Old Sep 20, 2005
i would do timing belt every 60k and replace the crank pulley with new. auto tranny fluid every 10k, oil change every 3k (or 10k with lc20), coolant whenever freezing point isn't low enough (measure with the floaty *****). But that's cause i love my car.
Old Sep 20, 2005
Jrfish007's Avatar
I go 7 k with the LC20
But I think any oil can go 5k without a problem. I love my car too but I'm cheap
Old Sep 20, 2005
tricky's Avatar
Let's see if I know the ledge
tricky is on a distinguished road
funny, here in Canada, everytime I call about the timing belt they keep telling me different times to come in, 1st time they said 160k, then 167k now its 170k...I'm at 162k and havent done it yet...so soon I will...haha
Old Oct 13, 2005
mrDFWmechanic's Avatar
i'm about to hit 50,000 and i was thinkin about doing a coolant flush so thats good and i changed my tranny oil at 35000. probably when i do my coolant i'm gonna get a honda thermostat
Old Oct 13, 2005
i'm getting timing belt done today with cam gear at 50k
Old Oct 14, 2005
Jrfish007's Avatar
DOn't forget to change the water pump... I would anyway
Old Oct 14, 2005
yes i changed water pump and crank pulley too, along with the seals.
Old Oct 14, 2005
did you do it yourself or have a shop do it?
Old Oct 14, 2005
shop did it. I don't have the tools or experience to mess with it.
Old Oct 14, 2005
chrisleecool's Avatar
i changed my radiator fluid at around 67k
and I haven't changed my "transmission fluid" since i bought the car new
and the car has 70k miles is this gonna be alright? or should i get it changed right away?
oh yea i have auto
Old Oct 14, 2005
i change tranny fluid every 10k. you're taking a huge chance going that long. Even the manual says every 30k.
Old Oct 15, 2005
Jrfish007's Avatar
My dad had a freind do his Accord once, and the guy didn't notice the timing slipped a hair when he took the timing belt off. He put the new one on and put everything back together, started the car backup and bent 7 valves. My dad spent $1200 to have heads comletely rebuilt. It's always tell people to take their cars to a good name place to have work like that done. I don't even screw with the timing belt unless I'm taking the entire engine apart, and even then I take to a good shop to have all the timing checked.
Old Nov 24, 2005
ericscorpse's Avatar
ericscorpse is an unknown quantity at this point
damn, I feel both stupid and lucky...121,935 miles and besides the oil I haven't changed **** at all. but this is my daily beater and not my fun car (240sx)
Old Nov 24, 2005
Storm897's Avatar
Storm897 is an unknown quantity at this point
Gearbox,
I called 2 Honda Dealerships on recommended parts to replace when doing my timing belt and they recommended the following:
1.) Replace Alternator Belt
2.) Replace Power Steering Belt
3.) Replace Water Pump & Water Pump Gasket
4.) Timing Belt Tensioner
5.) Timing Belt Tensioner Bolt (its only like $2 or something)
6.) OIL SEAL
7.) Replace Timing Belt
Who recommended you replace the crank pulley? Just wondering because I have a 2001 Civic with 92k miles and will be performing this service now.
Also, is the seal your talking about the oil seal (#19) in this picture?
Thanks,
Oren
Old Nov 25, 2005
there are two seals one is cam seal and the other is prolly oil. The crank pulley doesn't last very long because the rubber damper breaks apart over time. Usually around 60k miles. I pulled mine out and the rubber was already cracked and broken in many spots. The rubber is the damper that makes the pulley do its job and absorb crank vibration.
there is no need to replace accessory belts. they can be done anytime relatively easily by loosening a few bolts. also the timing belt tensioner almost never has a problem and is expensive too. no need to do that.
i feel so stupid taking to a shop to change the belt. now that i think about it, the manual makes it seem so easy compared to the head swap I'm gonna try this summer. Now that I know how its done, i can't see how they get away with charging so much. It really seems like a simple job. Pull off a few plastic covers, loosen the tensioner, pull off belt and put new on. check timing and done.
Old Nov 25, 2005
Storm897's Avatar
Where is the cam seal found? What number is it in this picture? Is it #4?
Perfect. I will also replace the crankshaft pulley as well (#13 in the picture below).
Where is the damper located? I will buy that also.
Thanks again in advance,
Oren
Old Nov 25, 2005
The rubber damper is build into the crank pulley. I'm not sure about which seals. The shop just ordered them for me.
Old Nov 25, 2005
Storm897's Avatar
Thanks Gearbox.
Just talked with someone from Majestic Honda. The two seals to replace are:
1.) Camshaft Seal - #19
2.) Crankshaft Oil Seal - #16
Thanks again,
Oren
Old Nov 26, 2005
when you do the seals, make sure you have the proper tools to install them with.
mattdoc
Mar 14, 2017 12:10 PM
Supramk3
May 11, 2015 07:55 PM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
CivicVoz
Apr 16, 2015 08:07 PM
