5w-30 vs 5w-20 vs 0w-20 vs 0w-30
Old Jun 5, 2005
jttegx's Avatar
OMNES AD UNUM
ive been using mobil 1 5w-30 for quite some time now. im thinking about going with either of the following 5w-20, 0w-20, or 0w-30. which of the few would suit me best for california summertime weather?
as of performance, gas mileage, and effectiveness to the engine. pros and cons of each?
Old Jun 5, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
u shouldve used 5w20 from the start, you can use that 5w30 but honda recommends going back to 5w20 after u used the 5w30
Old Jun 5, 2005
midnightblueEX's Avatar
midnightblueEX has a little shameless behaviour in the past
In the summer when its hotter i think its better to use thicker oil
Old Jun 8, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
eh. I've been using 0w20 mobil1 synthetic for a while ... seems ok. on the bottle, it says "recommended for ford and honda 0w20 and 5w20" ... so I thought it would be ok to use it.
unfortunately, from what I've heard (and seen), mobil has discontinued their 0w20 synthetic ...
Old Jun 8, 2005
S2000man01's Avatar
O RLY
you should really just use the 5w20 honda recommends. if you use 5w30, you are making your oil pump work harder.
Old Jun 10, 2005
jttegx's Avatar
OMNES AD UNUM
i was thinking about 0w-20, but couldnt find it neither for mobil 1. 5w-20 is rare to find. but would 5w-30 be exceptional for hard driving and heated weather?
which of the 2 would i see better performance/gas mileage?
Old Jun 10, 2005
ragingSPAM's Avatar
I just burnt my tongue
i use 0w-30 amsoil full synthetic 35,000 mile oil....i've done some fuel economy tests and i've gotten 39 mpg on the first and 40.2 on the second...it helps A LOT
Old Dec 27, 2008
johnnyboy5000's Avatar
johnnyboy5000 is an unknown quantity at this point
Re: 5w-30 vs 5w-20 vs 0w-20 vs 0w-30
I put one quart of 5W30 in with two and a half quarts of 5W20, since I didn't have enough 5W20 this past oil change. First time I've ever did this. Had a bit of 5W30 left over from the Toyota Yaris. Anyway, the result on my 02 Civic 151,000 miles, MT, is a MPG of 33 to 35 from 39 to 41 when I'm using straight up 5W20. Oh well.
Old Dec 27, 2008
04 Honda Civic's Avatar
Mobile 1 Synthetic 5w-20 is what I use
Old Dec 27, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
way to revive a 3 year old thread n00bs. lol.
Old Dec 27, 2008
Isn't it good forum etiquette to search for topic before creating a new one? The 7th gen civic and oil hasn't changed much since 2005.
Old Dec 27, 2008
sl33pyriceboi's Avatar
yes and no. yes if you have a quetsion and need more clarafication. no if ur jsut gonna comment on it on somethign thats actually been covered many many times.... theres a whole oil thread about this.
but its a public forum, wt can you do.
Old Jan 5, 2009
Psalm54's Avatar
Psalm54 is an unknown quantity at this point
YOU just did the one thing you are not supposed to do... and that is mix viscosities. My mechanic and the book says DO NOT DO THIS.... Honda recommends 5-20, but that is only due to the environmentalist wackos pressuring companies to get better fuel mileage. 5-30 is actually better for your motor
Old Jan 5, 2009
i use 5w30, it will shear down a bit anyway, and the mileage seems to have stayed the same. i like better engine protection.
Old Sep 26, 2019
SÃ mÃ's Avatar
Sà mà is an unknown quantity at this point
Cool Re: 5w-30 vs 5w-20 vs 0w-20 vs 0w-30
If the car calls for 0w20 or 5w20 then you should not exceed the 20
because of the tight tolorences of todays engines 30 may be to thick to penitrate between parts
when the engine in running full temp and the parts have expanded.
Old Jan 8, 2020
chuffsy's Avatar
chuffsy is an unknown quantity at this point
My toyota engine is a vvti engine and it is not wise for me to use thicker than recommended viscosities. The operation of the solenoids require this specification. I am not sure , honestly, if the 1.8L in our 2010 Civic being a vtec engine? requires a certain viscosity of oll as well. Comments?
Old Jan 8, 2020
Colin42's Avatar
Use what it says on the cap, or check your owner's manual
Old Nov 10, 2021
RaymondCasgrain's Avatar
RaymondCasgrain is an unknown quantity at this point
What ive gathered from this conversation is that you should not use 5w30 even though there are some people that say it's better, that we should listen to what honda says
Old Nov 11, 2021
FRSam's Avatar
Click Here
Just use what’s on the oil filler cap. There are some rare occasions where it may be beneficial to use thicker oil, but it’s safe to just use what’s recommended.
JBS36606
Jul 31, 2010 02:08 PM
Dticalman81
Buy, Sell, & Trade - Archive
Jul 27, 2008 02:07 AM
trev0006
May 29, 2006 02:13 PM
nitsuj1604
May 9, 2004 03:57 AM
