What clutch are you boosted members running?
After searching through a whole bunch of thread what are you guys running for your clutch setups? Flywheel, pressure plate, clutch, fluids.
stock for now........but after being boosted for 8 months, it is shot.
I will be installing a Exedy Organic with ACT Streetlite flywheel.
I was running ACT HDSS and ACT Streetlite and it was a pretty nice setup. However, I would go with the Exedy Organic and ACT Streetlite combination for two reasons.
1.) Exedy Organic increases torque capacity by 69% over stock while keeping a relatively stock pedal pressure feel.
2.) Exedy retails for much less than ACT.
Hope this helps!
Hope this helps!
I ended up going ACT heavy duty clutch kit w/ street disc and streetlite flywheel. ACT has a better warranty policy than Exedy though.
