90 civic will not pass emmisions test
Old May 6, 2008
caveboy's Avatar
caveboy is an unknown quantity at this point
I have a 1990 civic 1.5l that will not pass emmisions test. high nox
i have put a new cat. new oxygen sensor , new air filter. oil change , coolant change , i have tried retarding the timing , no luck, at my wits' end .
any ideas?
caveboy
Old May 15, 2008
C.R.E.A.M.'s Avatar
C.R.E.A.M. is an unknown quantity at this point
Re: 90 civic will not pass emmisions test
spark plugs,wires,distributor cap,rotor,coil and pcv valve.Did you change these parts?
lmk I have all of the above parts new and I could install them for you.
Old May 16, 2008
caveboy's Avatar
update:
found timing belt advanced 3 teeth on cam, also found out that "bosch" o2 sensors do not play well with hondas, changed o2 sensor to a "denso" now my car makes cleaner air than it takes in!!! passed emissions !!! BTW the car has 300k miles on it, still gets 38 mpg!!!!!
WAHOO!!! life is good once again!!!
caveboy
Old May 12, 2012
LukeJone's Avatar
LukeJone is an unknown quantity at this point
Change the oil, immediately go for emission insp. You'd be surprised at the impurities / gasoline in old motor oil.
Jonnie.
Jan 13, 2019 11:21 AM
usajags84
15
Aug 19, 2015 03:12 AM
CivicVoz
Apr 16, 2015 08:07 PM
BREADFAN
Apr 15, 2015 08:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
