Help! I can't get this rod out!
Old Oct 16, 2011
sukee's Avatar
sukee is an unknown quantity at this point
I'm trying to replace my daughter's lock actuator! (Thanks to the forum I have figured out that is what is wrong) I found the amazing instructions and I have unhooked the clips and disconnected all of the rods except for the one that is attached to the door handle. I used a flat head screw drive and used the door frame as leverage, but I still can't get that dang thing to move. I'm afraid I'm going to break that metal hinge it is connected to. Anyone else have any ideas how to get it unhooked?
Thanks
~Suzee
Old Oct 16, 2011
Re: Help! I can't get this rod out!
i sprayed it with pb blaster lube and used pliars. for some reason that one gets stuck. if i remember correctly, that plastic is snapped in place and wont come out easy. you might try pushing it from the back side with pliars. over time the plastic becomes brittle and hard, so it doesnt pop out like it should.
Old Oct 16, 2011
sukee's Avatar
Do you think WD40 would work the same? I have some of that!
Old Oct 16, 2011
it might, but wd40 is not really a penetrant or lubricant.
Old Oct 16, 2011
lazlong's Avatar
WD-40 will work fine. In a pinch pretty much any liquid will do. Try changing a tire by hand (and 2 giant pry bars) with degreaser in the middle of the desert. lol
Old Oct 17, 2011
Kennykid2002's Avatar
Kenny the Ricer
Tah, the annoying lock rod...
Please refer here:
https://www.civicforums.com/forums/1...ont-budge.html
Old Oct 17, 2011
sukee's Avatar
Thank you guys soooo much! WD40 and Kenny's illustration with the two screwdrivers, I got it out in under 5 mins!
Old Oct 17, 2011
Kenny the Ricer
No problem, glad we can help
rovafa2002
Sep 28, 2015 06:57 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
Joecrowe
Sep 24, 2015 09:12 AM
Butterfli13
Aug 12, 2015 11:04 PM
17
Jul 23, 2015 11:48 PM
