DIY: Refinishing Steel Rims (Video)
How to refinish steelies on a budget. This involves repainting your rims using spray bomb/rattle cans.
What you'll need:
flat screw driver, paint marker, wire brush, 200-400 grit sandpaper, brake cleaner, clean cloth, painter's tape, paper, dull knife/flat edge, primer, paint (color choice)
Procedure:
-remove rims from vehicle
-mark where wheel weight are located with paint marker
-remove loose rust and paint using wire brush
-sand down rim using 200-400 grit sand paper
-clean rim using brake cleaner and cloth, then let dry off in sun
-tape off tire and valve stem
-primer rim and allow for approximately 10min dry time
-apply selected paint choice (3 coats)
-let paint dry and remove tape
-reinstall wheel weight
-reinstall rim on vehicle
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1009& transactionid=1311975518-69633412&posted_by=ProStreetDriver_www.civicforums .com&youtube_video_id=TrZbx3jzdEc[/autostream]
What you'll need:
Procedure:
powman02
Sep 15, 2015 07:38 PM
Balkos
Sep 11, 2015 11:39 PM
tomas6791
Sep 11, 2015 06:47 PM
KikAzz
Sep 4, 2015 12:36 PM
