DIY clutch install
Old Nov 28, 2016
  #31
Colin42's Avatar
Re: DIY clutch install
it all depends on how much room you want when working on it, you can also pull the trans from the top, but you have to drain the coolant and remove the water passage thats above the tranny
Old Nov 30, 2016
  #32
honkeydonkey's Avatar
honkeydonkey has a spectacular aura abouthonkeydonkey has a spectacular aura about
I'm planning on doing my clutch in the next few weeks. Read about all 3 different ways, decided to go with the route of pulling it out the top. Subframe sounds like its tough to remove. I just need to pull the water passage off the side of the engine where the thermostat is and EGR valve. ISB is screwed or else I would just leave it in the car like in this DIY. Going to take the opportunity and change ball joints and brakes at the same time as well as my cat since i've got a p0420 code.
Old Dec 1, 2016
  #33
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Originally Posted by Barba8756
To those of you who have done this job, it this the way to go or should I plan on dropping the subframe and transmission completely out?
Like in the DIY I didn't remove the subframe, I had two jacks, one under the engine and one under the tranny, With a block of wood between the transmission and the jack it was easy enough to slide the transmission over to the control arm and wedging it in there. It was kind of tight trying to get to the flywheel off but it's manageable.
Yeah this seems like it would suck. I usually try to just mess with one system at a time just eliminate the chance of screwing something up.
Old Dec 2, 2016
  #34
Colin42's Avatar
I was swapping the trans so I did it that way so I didn't have to unbolt the subframe, the car probably needed the coolant changed anyways
Old Jul 28, 2017
  #35
Kingcredible's Avatar
Kingcredible is an unknown quantity at this point
Thank you for the hard work, 12 years later and this thread is still helping us!!
Old Sep 2, 2017
  #36
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
i can't believe this is still up
it survived the test of time
Old May 10, 2023
  #37
pats73's Avatar
pats73 is an unknown quantity at this point
EpicAF post bro! Wow! Thank you!
Youshoe
May 22, 2015 09:36 PM
bsmiley
Apr 27, 2015 01:27 PM
meels808
Nov 20, 2001 09:37 AM
ROBREALZCIVIC
Nov 16, 2001 06:53 PM
clownprince
Nov 15, 2001 01:37 PM
