What a properly indexed strut looks like *pics*
Old 04-04-2004
flotsamm's Avatar
I took my drivers side off today to check out if I had indexed it right when I put my Koni's a while back ago. I didnt, so I fixed it and decided to take a pic since I had it apart. If you removed the spring for any reason(like installing new ones), make sure that you reassemble it correctly or you'll get popping noises when turning. Alot of people know this already, but for those who dont this might help you. I took this picture with the spring removed so you could see the hole on the lower perch easier.
To properly reassemble the strut, you must first make sure that the spring is seated in the lower perch correctly. Then you must line up the two triangles on the top mount and upper spring perch with the hole on the lower spring perch. Here's a pic of what I mean. Just line up the three circles in a straight vertical line, while making sure the top perch rubber isolator is seated correctly on the top of the spring. Then slowly remove your spring compressor making sure the spring doesnt move around.
Once your all done, it should look like this:
After the spring compressor is removed, make sure that the spring is still seated properly on the lower perch and that everything is lined up as close as possible. If not compress the spring again and realign. Once its all lined up and the spring is seated correctly, reinstall the strut assembly in the car. Remember that once you get the strut in and install the pinch bolts and top nuts, to preload the strut a little with a floor jack. Preloading will help remove any spaces and loose sections that can cause noise. Make sure you DONT put the floor jack on the flat part of the lower control arm or you could bend it. Then tighten the pinch bolts and top nuts enough so they wont move. Remove the jack and torque everything down to spec.
Hope this helps...
The following users liked this post:
IStoev (10-26-2020)
Old 04-04-2004
I Queef > You
sKwiD's Avatar
sKwiD is on a distinguished road
Wow, I didn't know that! Thats probably why my suspension makes popping and buzzing noises sometimes. This goes for the rear springs too?
Old 04-05-2004
spencerkam's Avatar
spencerkam is an unknown quantity at this point
oh damn. i didn't even notice this on my friends car when we did his.
Old 04-05-2004
flotsamm's Avatar
Heheh yeah I didnt know this either until I studied my Helms manual a little closer. The Helms manual shows you how to do this, but my parts differ from what illustrated so I didnt get it the first time around either.
For the rears its not as critical to get the perches lined up since you dont have to index them. As long as the spring is seated correctly it should be fine.
Old 04-05-2004
E®ik's Avatar
E®ik will become famous soon enoughE®ik will become famous soon enough
Would you hear these popping noises even when the car is in motion, or just when it is at a stand still? I have a little bit of that "popping" noise while at a standstill, well and a little of what we call coil bind ....
Old 04-05-2004
Logan3024's Avatar
GREAT INFO!!! All these out of alignment will create poping noises. Very important detail
Old 04-05-2004
flotsamm's Avatar
It can happen in both conditions, either standing still or moving and turning.
Old 04-07-2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Flotsamm, I noticed that you have installed your springs with the closer spaced coils on the top. Aren't they suppose to be on the bottom ? Anyone can clarify this ?
Old 04-07-2004
OMNES AD UNUM
jttegx's Avatar
is this why my skunk2 coilovers with stock shocks make those popping/clanking noises? i would've greased them up but no grease around at the time.
Old 04-07-2004
flotsamm's Avatar
In the front, I'm pretty sure that they will only go in one way with a progressive spring. With the closer spaced coils you wouldnt be able to seat the spring correctly on the lower perch since the angle isnt as steep. Though I could be wrong.. hrmm I actually didnt try it the other way around.
For the rear, the dead coils go on the bottom.
Old 04-07-2004
flotsamm's Avatar
Hrmm that I dont know since I'm not familiar with Skunk2 coil overs. If theyre designed to work like a stock spring and use the same upper mount and upper perch then it should be indexed like stock I assume.
Old 04-08-2004
7gen03's Avatar
7gen03 is an unknown quantity at this point
its crucial to know this if you look at the lower seat for the spring you will notice it is angled. This angle is also matched on the top retainer for the spring they need to match thats the reason for the marks if they dont there will not be enough pre-load on the spring and the spring will rotate in the strut causing your poping and piniung noises
I believe this is only on 2002 and halfs up
7gen03
Old 06-12-2004
flotsamm's Avatar
I might be wrong in my post above about indexing. My Helms manual says that your suppose to line up the arrows on the top mount and upper perch with the knuckle mounting area(or hole on lower perch). I did this, and I still had some popping and what sounded like coil bind. Today, after installing some Progress springs on my nephews RSX I noticed that the knuckle mounting area wasnt lined up with the arrows, but instead with the paint marks(see above pics, the yellow paint marks is what I'm referring to). This is the way it came stock on his car. So I installed them using the paint marks and he has no problems with popping. This got me curious so when I got home today I redid my struts using the paint marks also and now it doesnt pop. I still had a little coil binding noise when turning right but its no where near as bad as was. So it might be something to test out. Perhaps this is why they put the damn paint marks on there! DOH.. hrmm. Not sure but something to try since it helped me get rid of the noises.
Old 06-13-2004
sffree's Avatar
sffree is an unknown quantity at this point
yo.. flotsamm.. please re-explain this new indexing method using the paint marks... recall that I had the popping noise on my pro kit/koni set up.. After re-indexing using the arrows and the hole on the knucle mount, the popping was less but still there... I'm taking the car to have the strut assembly checked again and want to know what to tell the guy... so is it basically lining up the 2 paint marks on the 2 upper mount pieces with the hole on the bottom perch? Should I ignore the arrows?
Old 06-14-2004
flotsamm's Avatar
Yup.. after doing my nephews RSX over the weekend and seeing how is was indexed using the paint marks instead of the arrows, I went a re-did mine. After using the paint marks instead of the arrow on the upper perch, my struts no longer make this popping noise when coming to a stop or taking off. It sounded like a CV joint going bad, but it wasnt. Now my car seems to track alot better now when driving down the freeway(feels like it was when I first got it) and takes less effort to steer. I still have some coil bind noise, but its much better then it was and less noisy.
After taking closer at the struts, I found my original index line that I scratched into the upper perch when I fiirst installed my Sportlines. The index line matches up with the paint marks, so I'm fairly certain that this may be the way Honda assmbles them.
What I dont get is why my Helms manual says to use the arrows, but when you take them out its using the paint marks instead. Go figure. Anyways, might be worth trying for some peeps.
Old 06-15-2004
sffree's Avatar
what's the coil bind from? is it related to the indexing?
Old 06-15-2004
flotsamm's Avatar
The coil bind is from the spring coils rubbing against each other when the spring is twisted when I turn the wheel. It only happens when I'm parked and turning the wheel, or driving really slow and turning. I might have to try installing some coil wrap and see if it helps some.
It could be related to indexing, since if the strut insnt indexed right the spring wont be seated in the perches correctly. But I've done it both way now(the Helms method using the arrows and now the factory method using the paint marks) and the paint marks method seems to be better and less noisy then the Helms method.
Old 04-18-2007
lid6662's Avatar
lid6662 is an unknown quantity at this point
Re: What a properly indexed strut looks like *pics*
If I have a friend to help me and has power tools , how long would u guess it would take to reindex the strut on just the drivers side?
Old 04-18-2007
Pwning Noobs 24/7
DaMadScientist's Avatar
DaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really niceDaMadScientist is just really nice
probably like 30 minutes given you know what you are doing....the two marks dont have to be perfectly aligned they can be a little off
Old 04-18-2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I'd say for a 1 hour if you dont rush.
Remember you'll need to take the strut appart, allign strut cup mark to strut mrk, assemble the whole thing together and put back on.
Old 04-18-2007
Pwning Noobs 24/7
yea its defineatly a 2 person job
Old 04-18-2007
If you know what you're doing, then you can handle this job alone.
I had to redo my struts before I was made aware of indexing.
Old 04-18-2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
I've just always lined up the two top arrows and have never had any problems, and I've changed springs countless times. Maybe I just get lucky and it always lines up right?
Old 11-01-2016
Ekhriz's Avatar
Ekhriz is an unknown quantity at this point
Hope this helps...
Damn I put the jack exactly where you said not to put it. Now looks like my strut doesn't fit. How can aliviate the situation? Put pressure back into the control arm? Also is my spring upside down or is that the right way and I ask that just because the letters are upside down. One last thing. The top hat should say R since I was working on the passenger front side correct?
ID:	89203   Click image for larger version
Old 04-28-2020
es2 beater's Avatar
es2 beater is an unknown quantity at this point
TTIWWOP! Anyone have a pic of what an indexed spring looks like?
Old 08-16-2022
That7thGenGuy's Avatar
That7thGenGuy is an unknown quantity at this point
Hate to revive an old thread but it IS a sticky. Where are the photos in the OP??? Thanks!
Old 08-16-2022
Colin42's Avatar
Received 1,126 Likes on 941 Posts
Probably long gone due to Photobucket
SammySC
121
04-07-2017 07:43 PM
skeener51
10-01-2015 05:56 PM
Tedverseti
09-29-2015 05:41 PM
meicalnissyen
Suspension
09-24-2015 09:28 PM
speedlever
09-24-2015 07:18 PM
Quick Reply: What a properly indexed strut looks like *pics*
