Replacing the hood?
Old Jul 12, 2011
Setzer77's Avatar
Setzer77 is an unknown quantity at this point
Replacing the hood?
Hey all. I hit a deer a couple months ago, the only real damage done was to the hood, which is understandably mangled (but still latches, go Honda!). Body shop wants $1500 to fix the hood and some little bracket in the front of the engine (only a small part of it is remotely bent, and seemingly affects nothing). Seems to me I can just buy an OEM hood and replace the thing myself, but I'm not 100% on that. I have NO mechanical experience, but I am mechanically inclined. Is this just a direct swap with a few tools, or is there something more to it? Are all the necessary holes and such (wiper nozzles, hinge brackets, etc) already in place, or do those need to be drilled? Also, since it would be an OEM part, the latch loop should already be installed, right? I'm not looking for anything fancy, just an OEM replacement so my car doesn't look like sh....well, you get the picture.
Thanks to any and all for advice.
Old Jul 12, 2011
Re: Replacing the hood?
It should be a straight swap. 4 bolts is all that secures it to the hinges.
Can you show us a pic of the bracket that's bent?
Old Jul 12, 2011
Setzer77's Avatar
Certainly. Here's multiple angles of everything.
usajags84
15
Aug 19, 2015 03:12 AM
crowtoo
May 11, 2015 06:50 PM
thesushiboy
Apr 12, 2015 02:54 AM
ALLMAN
Engine DIY
73
Jan 19, 2009 11:21 PM
CivicHX01
Nov 29, 2001 03:48 PM
