DIY: Y8 Intake Manifold Swap on D17A2-Ver. 2
Re: DIY: Y8 Intake Manifold Swap on D17A2-Ver. 2
Hello again sorry to be a bother but Is there any way you could look at yours and let me know what color wires is for the throttle position sensor and same for map sensor? I got them mixed up and the plugs are same but harness wire colors are different I don't need to burn a ECU up getting the mixed up. Thanks
Which injectors did you use?
DaMadScientist
Engine building
16
May 17, 2017 02:05 PM
cdmx
Nov 2, 2003 12:46 AM
